Originally Posted by Beamed
(Post 7737739)
I would suggest a new coil to anyone with alot of miles on their truck. made a really big difference. and changed her oil.
Originally Posted by 93 mix 'n match
(Post 7737899)
is 305,000 alot of miles? just wonderin.....8D
Originally Posted by TexasGuy001
(Post 7737933)
Do you have that many on your truck? I have 270+ on mine.
Thats cool!
I agree with the statement in your sig "think before you lift". I actually made the mistake years ago by doing just that and a few years later took all that stuff off. The only thing cool about all of it was maybe the way it looked. I actually love the truck even more in close to stock form. It had Ranch Hand bumpers, 32s and basically a 4 lift. All that lift and tires and bumpers etc did was give poor performance, poor fuel economy, poor handling, poor braking, and poor ride quaity. https://www.ford-trucks.com/user_gal...id=202585&.jpg https://www.ford-trucks.com/user_gal...id=218506&.jpg |
I think lifts are pointless on anything that's gonna spend less then 50% of its lifted life on dirt. If you lived on a bumpy dirt road with pot holes deep enoug that there might be a volkswagon at the bottom, I can see a lift. If your a logger or a contractor or in any occupation that requires you to go off the beaten path, then I can understand a lift. But the lift just to look cool or to occasionally wheel is stupid. The thing I hate more is 6 inch+ lifts on 2wd trucks. The only lifted 2wd truck I like is Bill's. But Bill has a locker so its a little bit better offroas then a standard 2wd loose rear.
Your truck didn't look that bad lifted. How bad was difference? |
I have gotten to the point were I basically agree about lifts being pointless except on trucks that need some lift because of what they are used for.
Actually I was trying to convince Bill to put his back to stock ride height and put street tires on it like mine. I think 2wd reg cab flaresides are a perfect candidate for a street truck. Of course he would need to change the gears again. My truck was fairly capable off road. It originally came with 3.08 gears. I swapped to the 3.55 LS at the same time I lifted it. Although it could go in places where I would have thought it would get stuck, I didn't go off roading much at all. I was fairly impressed though. This was really the only good thing about it. As far as how bad it was.... well the fuel economy was 12 or so. I get 17 or 18 currently. This is city highway mix. It would road wander even with rebuild front suspension and steering and a single steering stabilizer. I kept the stabilizer when I removed the lift. It went through brake pads about every 2 years. I haven't done the brakes since I put it back to stock about 3 or so years ago and the pads still look great. Also, the stopping distance was greatly increased it took much more room to slow down. It did not like to tow at all. It tows a lot better now. On longer trips it gave driver fatigue it was so bad to drive. The handling flat out sucked. Several times I thought I was going to have an accident. All of that is gone since I removed all the suspension lift parts. I should never have wasted my time with it. At least I was able to sell the parts and get some money back out of it. I actually sold the All Terrain tires that were about half shot at the time for enough to buy the TAs and a generic road hugger spare of the same size. |
lifts, i agree and disagree, mine has been lifted all its life towing really isnt an issue on most items since i put the larger springs in. nothing with the lift has really ever given me trouble , i dont take mine off road, but the heavier suspesion helps with towing
(Post 7738219)
Originally Posted by jk89cat
(Post 7738594)
Installed new set of taillights with a minor modification. Check em out.
http://i179.photobucket.com/albums/w..._442/cl014.jpg http://i179.photobucket.com/albums/w..._442/cl013.jpg |
What was the point of eliminating the reverse lights? Do they function as an extra brake light or tail light now.
Got my new AFE Dryflow fliter in, after i reinstalled the stock air intake and pulled the K@N Hotair intake off, i'll get a current MPG Check soon.
http://i40.photobucket.com/albums/e2...s/DSCN0096.jpg |
Thats cool Jason! I'm glad to see that you got it. Did you find a new MAF sensor gasket?
(Post 7741257)
Are they wired up to a switch or to reverse? What do the old reverse lights do now, come on as tail lights or brake lights or nothing? How did you recolor the lense?
I have auxilary reverse lights but put them on a switch so I can use them whenever I need them like hooking up a trailer in the dark. |
