I finally pulled the rear end cover and change the lube. Been puting that off forever....
Replaced the carpet on the back wall of the cab yesterday
Installed my maual oil pressure guage after finally getting the old sending unit off with some difficulty. Holds about 50 lbs. at idle.
i just sat for a minute and looked at him sayin ,,,,why do you have to use so much damn gas lmao.....damn that sweet 460 !!!!!
https://www.ford-trucks.com/forums/p...pictureid=4529 :-missingt:-missingt:-missingt:-missingt:-missingt:-missingt:-jammin:-jammin:-jammin:-jammin:-jammin:-jammin |
Originally Posted by 6CylBill
(Post 7391197)
I think they did. I like the shiny look but can't get it with the regular Armoral. I haven't found anything that really makes tires shine tho. I should start looking around.
best trick i have found is break fluid.... stays wet lookin longer than anything,,,,only problom is if ya drive threw dirt go slow cause it picks it up really easy ,,,,but it also washes off at the carwash easy too :-drink |
I washed it today, but the pollen from the pine trees is so bad, it went from red to yellow in about 3 hours!
Originally Posted by Old93junk
(Post 7409880)
I washed it today, but the pollen from the pine trees is so bad...
Originally Posted by MontanaMan
(Post 7410809)
Do you get pine sap on yours? How do you get it off?
I washed her and cleaned her today
http://[IMG]http://i724.photobucket....g50hc/sddf.jpg[/IMG] http://[IMG]http://i724.photobucket..../untitled8.jpg[/IMG] |
I tried hitting it with a hammer, but the pine sap was still there ...
Well, replace a "blown" radiator, changed the oil and cleaned out the interior. Oh replace the dome light. Still investigating rear axle seal or wheel cylinder. We shall see.
(Post 7411820)
Trucks running fine so don't have to do much it. I did change the power steering fluid. I used Castrol Type F automatic transmission fluid. The next thing on my list is to fix the power windows.
ripped up the original cracked dash pad and put my own black vinyl on
went from this http://i570.photobucket.com/albums/s...ashpadfoam.jpg to this http://i570.photobucket.com/albums/s...ordashpad1.jpg |
Tightened Exhaust
I tightened up my exhaust pipes to my headers to fix an exhaust leak.
