stock breathing on 89 f250?
The stock air filter for my new to me 1989 F250 with 460 seems pretty small. what mods do most guys do with these? I want to put a freer flowing muffler with 3" exhuast but it seems the stock air cleaner is a bigger restriction than the exhuast.
just bumping back to the top. Anyone recommend an intake for a 89 f250 with a 460. Most of the companies I have checked don't make them for that use so wonder if there is a reason.
bump back to the top
try going to
s&bfilters.com they have a cold air intake system for your truck. |
sorry make that
sbfilters.com |
you know K&N has the cold air filter intake also,
not sure about the part number but try KNN572503? |
Thanks. that helps a bunch. Do you know if 89 vintage 460's had MASS air or not? Thanks.
I have'nt got that far yet on my 89' but I don't think it does have mass air.
So dont want to steer you in the wrong direction, all I know is that cold air intake filter kit has a place for two intake hoses, You can also go to FordFuelInjection.com that site has some real good info on what you should know about your system (engine). |
Yea, the K&N Fipk and S&B filters should fit your truck: http://motorhaven.autoanything.com/air-intakes/20A50096A1.aspx
I'm not sure about the maf... |
