Holley carb
I was wondering what cfm the holley was that came on the 86 351 H.O.
If Stock it is a 600 CFM Holley 4180. The 4180 was a smog carb that was built by Holley for Motorcraft. The tag on it is very important if you ever have to rebuild it. It contains a Motorcraft # NOT HOLLEY#.
Holly 4180 and Ford 5.8H.O carburetor
I am trying to figure out what type of carb I have on my
1986 Ford Bronco. 351 winsor with elec. choke. all stock original owner. Local ford dealer no help. The list number I found is list 50264-1 and just below that number is 1606 I need to get a rebuilt kit, but not sure of the Holley Number. Is this a 4180? If so will the 3-1346 holley kit work? Another number at the top is ??5TE 9510 ZB Thanks Bob |
Bob, that is E5TE and that number (E5TE ZB) at a good parts store should get you a kit.
Remember first numbers...C=6, D=7 and E=8 (E5 is therefore 85). Kenny |
Thanks Kenny
Since this is an 86 Bronco, I guess the carb was built in 85. I am going to get the Holley rebuild kit and give it a try. The carb has not been much trouble over the years, except it will not pass a gas station, about 10mpg around town. Bob |
