Holley carb - Ford Truck Enthusiasts Forums
Holley carb
Old 07-20-2007, 05:19 AM
Shovelhead 93's Avatar
Shovelhead 93 Shovelhead 93 is offline
Shovelhead 93 is starting off with a positive reputation.
Holley carb
I was wondering what cfm the holley was that came on the 86 351 H.O.
Old 07-20-2007, 03:08 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
If Stock it is a 600 CFM Holley 4180. The 4180 was a smog carb that was built by Holley for Motorcraft. The tag on it is very important if you ever have to rebuild it. It contains a Motorcraft # NOT HOLLEY#.
Old 08-20-2007, 10:23 PM
steel120 steel120 is offline
steel120 is starting off with a positive reputation.
Holly 4180 and Ford 5.8H.O carburetor
I am trying to figure out what type of carb I have on my
1986 Ford Bronco. 351 winsor with elec. choke. all stock original owner. Local ford dealer no help.
The list number I found is list 50264-1
and just below that number is 1606
I need to get a rebuilt kit, but not sure of the Holley Number.
Is this a 4180? If so will the 3-1346 holley kit work?
Another number at the top is ??5TE 9510 ZB
Thanks Bob
Old 08-21-2007, 02:32 PM
mudgepondexpress mudgepondexpress is offline
mudgepondexpress is starting off with a positive reputation.
Bob, that is E5TE and that number (E5TE ZB) at a good parts store should get you a kit.
Remember first numbers...C=6, D=7 and E=8 (E5 is therefore 85).
Kenny
Old 08-22-2007, 09:25 AM
Thanks Kenny
Since this is an 86 Bronco, I guess the carb was built in 85.
I am going to get the Holley rebuild kit and give it a try.
The carb has not been much trouble over the years, except it will not pass a gas station, about 10mpg around town.
Bob
4180 Holley GeneGregory Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 05-24-2015 11:25 AM
1957 F100 223 Holley carb. mgargiullo 1957 - 1960 F100 & Larger F-Series Trucks 14 01-29-2014 11:57 AM
Do I need a different rebuild kit for a Motorcraft Holley? stercorarius FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 08-01-2013 04:56 AM
Holley carb on 86 351 ho hwknsdrag 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2012 06:12 PM
Holley "Thunder" Supercharger Performance & General Engine Building 4 03-24-2002 06:47 PM
Tags
4180, 502641, 9510zb, carburetor, cfm, cfms, e5te, e5te9510zb, e5tezb, ford, holley, kit, list, motorcraft, rebuild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
