Diagram for C6 Transmission
Does anyone know where to find diagrams for the C6 transmission ONLINE or for the valve body within ?
What's your email? I've printed a 20 page instruction for the assembly (with diagrams) of the C6 into a tif file. Perhaps it will be of some help to you.
-Chris |
Scratch that, I found the valve body diagram:
http://i170.-----------.com/albums/u...6valvebody.gif 1 — Shift Valve Plate (Part of 7A100) 2 — 2-3 Shift Valve (Part of 7A100) 3 — Throttle Modulating Valve Spring (Part of 7A100) 4 — 2-3 Backout Valve (Part of 7A100) 5 — Inner Intermediate Servo Accumulator Spring (Part of 7A100) 6 — Outer Intermediate Servo Accumulator Spring (Part of 7A100) 7 — Intermediate Servo Accumulator Valve (Part of 7A100) 8 — Intermediate Servo Modulator Valve Spring (Part of 7A100) 9 — Intermediate Servo Modulator Valve (Part of 7A100) 10 — 2-1 Scheduling Valve (Part of 7A100) 11 — 2-1 Scheduling Valve Spring (Part of 7A100) 12 — Throttle Pressure Booster Valve Spring (Part of 7A100) 13 — Throttle Pressure Boost Valve (Part of 7A100) 14 — Throttle Pressure Booster Plate (Part of 7A100) 15 7D227 Throttle Pressure Valve Secondary Spacer 16 — Downshift Valve Spring (Part of 7A100) 17 — Gear Selector Valve Rod (Part of 7A100) 18 — Throttle Downshift Valve (Part of 7A100) 19 — Manual Valve Retaining Pin (Part of 7A100) 20 — Throttle Pressure Relief Spring (Part of 7A100) 21 — Throttle Pressure Relief Check Ball, 1/4-Inch Diameter (Part of 7A100) 22 — Spring Seat (Part of 7A100) 23 — Boost Valve Spring (Part of 7A100) 24 — Pressure Regulator Spring (Part of 7A100) 25 — Booster Valve (Part of 7A100) 26 — Retaining Clip (Part of 7A100) 27 — Main Fluid Pressure Boost Valve Sleeve (Part of 7A100) 28 — Reverse Clutch Check Ball (Part of 7A100) 29 — Main Regulator Valve (Part of 7A100) 30 — 2-3 Shift Valve Check Ball (Part of 7A100) 31 — Converter Pressure Relief Valve (Part of 7A100) 32 — Converter Pressure Relief Spring (Part of 7A100) 33 — Upper Control Valve Body (Part of 7A100) 34 — 2-3 Backout Valve Spring (Part of 7A100) 35 — Throttle Modulator Valve (Part of 7A100) 36 — Cutback Control Valve (Part of 7A100) 37 — Line Pressure Coast Valve (Part of 7A100) 38 — 1-2 Shift Valve Spring (Part of 7A100) 39 — DR-2 Shift Valve (Part of 7A100) 40 — 1-2 Shift Valve (Part of 7A100) Enjoy -Chris |
wow i'm glad to see somebody else was requesting this kind of info on a c6 other than me haha. do you by chance still have those 20 pages downloaded to send? my email is marklee57@ live.com
Chris does not post on this site anymore.
You would have to post over on the site he uses now. |
Originally Posted by Skandocious
(Post 4849999)
-Chris |
Originally Posted by Kris Marriott
(Post 16918018)
Do you still have them? If so, do you have an electronic file like a pdf or Word document?
Read the post directly above yours. tl;dr version: no |
Zombie post
(Post 16918018)
