Diagram for C6 Transmission - Ford Truck Enthusiasts Forums
Old 06-18-2007, 11:57 AM
Jam Ras Jam Ras is offline
Jam Ras is starting off with a positive reputation.
Does anyone know where to find diagrams for the C6 transmission ONLINE or for the valve body within ?
Old 06-18-2007, 12:37 PM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE.Skandocious is gaining momentum as a positive member of FTE.
What's your email? I've printed a 20 page instruction for the assembly (with diagrams) of the C6 into a tif file. Perhaps it will be of some help to you.
-Chris
Old 06-18-2007, 12:44 PM
Scratch that, I found the valve body diagram:
1 Shift Valve Plate
(Part of 7A100)
2 2-3 Shift Valve
(Part of 7A100)
3 Throttle Modulating Valve Spring (Part of 7A100)
4 2-3 Backout Valve
(Part of 7A100)
5 Inner Intermediate Servo Accumulator Spring
(Part of 7A100)
6 Outer Intermediate Servo Accumulator Spring
(Part of 7A100)
7 Intermediate Servo Accumulator Valve
(Part of 7A100)
8 Intermediate Servo Modulator Valve Spring
(Part of 7A100)
9 Intermediate Servo Modulator Valve
(Part of 7A100)
10 2-1 Scheduling Valve
(Part of 7A100)
11 2-1 Scheduling Valve Spring (Part of 7A100)
12 Throttle Pressure Booster Valve Spring (Part of 7A100)
13 Throttle Pressure Boost Valve (Part of 7A100)
14 Throttle Pressure Booster Plate (Part of 7A100)
15 7D227 Throttle Pressure Valve Secondary Spacer
16 Downshift Valve Spring
(Part of 7A100)
17 Gear Selector Valve Rod (Part of 7A100)
18 Throttle Downshift Valve (Part of 7A100)
19 Manual Valve Retaining Pin (Part of 7A100)
20 Throttle Pressure Relief Spring (Part of 7A100)
21 Throttle Pressure Relief Check Ball, 1/4-Inch Diameter
(Part of 7A100)
22 Spring Seat (Part of 7A100)
23 Boost Valve Spring
(Part of 7A100)
24 Pressure Regulator Spring (Part of 7A100)
25 Booster Valve
(Part of 7A100)
26 Retaining Clip
(Part of 7A100)
27 Main Fluid Pressure Boost Valve Sleeve (Part of 7A100)
28 Reverse Clutch Check Ball (Part of 7A100)
29 Main Regulator Valve
(Part of 7A100)
30 2-3 Shift Valve Check Ball (Part of 7A100)
31 Converter Pressure Relief Valve (Part of 7A100)
32 Converter Pressure Relief Spring (Part of 7A100)
33 Upper Control Valve Body
(Part of 7A100)
34 2-3 Backout Valve Spring (Part of 7A100)
35 Throttle Modulator Valve (Part of 7A100)
36 Cutback Control Valve
(Part of 7A100)
37 Line Pressure Coast Valve (Part of 7A100)
38 1-2 Shift Valve Spring
(Part of 7A100)
39 DR-2 Shift Valve
(Part of 7A100)
40 1-2 Shift Valve
(Part of 7A100)
Enjoy
-Chris
Old 04-14-2011, 12:32 PM
Mark57Lee Mark57Lee is offline
Mark57Lee is starting off with a positive reputation.
wow i'm glad to see somebody else was requesting this kind of info on a c6 other than me haha. do you by chance still have those 20 pages downloaded to send? my email is marklee57@ live.com
Old 04-14-2011, 03:09 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Chris does not post on this site anymore.
You would have to post over on the site he uses now.
Old 02-02-2017, 04:32 AM
Kris Marriott Kris Marriott is offline
Kris Marriott is starting off with a positive reputation.
Quote:
-Chris
Do you still have them? If so, do you have an electronic file like a pdf or Word document?
Old 02-02-2017, 10:29 AM
bbf385's Avatar
bbf385 bbf385 is offline
bbf385 has a good reputation on FTE.bbf385 has a good reputation on FTE.
Quote:
Read the post directly above yours.
tl;dr version: no
Old 02-02-2017, 10:37 AM
raystankewitz's Avatar
raystankewitz raystankewitz is online now
raystankewitz is gaining momentum as a positive member of FTE.
Zombie post
Nice necropost. 6 year old dead thread.
Vacuum diagrams; where to find them tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 10 02-15-2017 09:28 AM
1994 f250 connector c103 diagram BearFootCustom 1987 - 1996 F150 & Larger F-Series Trucks 4 07-18-2016 09:24 PM
302 EFI C6 kick-down help 85MOTORSPORTXLT 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 05-02-2016 10:44 AM
New user with '79 F-150 vacuum question ewmeassoc 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-03-2015 08:45 PM
02' Excursion Wiring Diagram Bobsandog Excursion - King of SUVs 1 07-19-2012 05:44 PM
Tags
7a100, ball, body, c6, check, diagram, ford, intermdiate, modulator, parts, pressure, relief, servo, spring, throttle, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
