Need a safty inspection!
ok, suggestions as to a place to go?
or dose anyone do safty? i havent taken my truck in yet, but im betting it will fail for an exhaust leak at the manifold. let me know! |
I forgot...where ya at?
missouri that is, meth labs...cardnals fans.... |
Originally Posted by Kikkinasphalt
st louis
missouri that is, meth labs...cardnals fans.... slmann or century should be by shortly with safety inspection info for ya. I'm on the other end of Missouri. |
Boy oh boy, I couldn't have said that better myself! :-D
slmann or century should be by shortly with safety inspection info for ya. I'm on the other end of Missouri. uncle sam wont know, and missouri is too busy rippin us off elsewere |
I don't know of any that you can go and be sure to pass. Try a small independent shop you might have better luck at one of those.
Or maybe not. I'm in KC and just had to check around a bit before I found a shop that passed my truck. And in the unlikely event you've seen the inaugural fte missouri chapter truck of the month, I'm pretty sure you'd know that the inspection was a ringer. :-X07
Originally Posted by Century Coronado
I thought you had more connections than AT&T...:rolleyes:
Me, I thought for sure you would have a long list of places to go. :D
I'll bet you a nickel that he's got a short list of where you can go...:-missingt
Not sure what year truck that you need the inspection but if the truck is over 25 years old there is a special provision in the Missouri historical plate statute that allows you to use a plate from the same year that the truck was manufactured. If you can find one and nobody is currently using that plate number they will reactivate that plate.
My F100 is a 1956 so I found a Missouri 56 truck plate on Ebay for $10. The State ran the numbers thru the system and found nobody currently using that particular number so they reactivated that plate. The beauty of the system is that there is no yearly inspection and no yearly smog inspection required. There is no renewal fee either - pay $25 up front and the plate is good for as long as you own the vehicle. The down side is that you need to keep a mileage log in the vehicle in case Missouri's finest stop you. |
the truck is an 84
so its 20 years old not old enough |
If you can hold out for a few more months, as of the 1st of the year, no more inspections, but until then....
thats what I like about FTE, Even though I'm an inspector, I never heard of that!
