Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
  #1 (permalink)
Old 10-16-2006, 01:45 PM
Kikkinasphalt Kikkinasphalt is offline
Garage is empty, add now
Kikkinasphalt is starting off with a positive reputation.
Need a safty inspection!
ok, suggestions as to a place to go?
or dose anyone do safty?
i havent taken my truck in yet, but im betting it will fail for an exhaust leak at the manifold.
let me know!
  #2 (permalink)
Old 10-16-2006, 02:50 PM
tcbofade's Avatar
tcbofade tcbofade is offline
1986 Ford F-150
tcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputation
I forgot...where ya at?
__________________
Join the Missouri Chapter!
If my Aunt had stones, she'd be my Uncle...
  #3 (permalink)
Old 10-16-2006, 03:17 PM
Quote:
st louis
missouri that is, meth labs...cardnals fans....
  #4 (permalink)
Old 10-16-2006, 03:23 PM
tcbofade's Avatar
1986 Ford F-150
Quote:
Originally Posted by Kikkinasphalt
st louis
Boy oh boy, I couldn't have said that better myself!
slmann or century should be by shortly with safety inspection info for ya. I'm on the other end of Missouri.
__________________
  #5 (permalink)
Old 10-16-2006, 03:40 PM
LMAO mail it to me!
uncle sam wont know, and missouri is too busy rippin us off elsewere
  #6 (permalink)
Old 10-16-2006, 06:01 PM
slmann slmann is offline
slmann is gaining momentum as a positive member of FTE.
I don't know of any that you can go and be sure to pass. Try a small independent shop you might have better luck at one of those.
__________________
2004 F-150 Supercab 4x4
Come visit the Missouri chapter
  #7 (permalink)
Old 10-16-2006, 06:31 PM
Century Coronado Century Coronado is offline
Century Coronado is starting off with a positive reputation.
Quote:
I thought you had more connections than AT&T...
  #8 (permalink)
Old 10-16-2006, 06:44 PM
tcbofade's Avatar
1986 Ford F-150
Or maybe not. I'm in KC and just had to check around a bit before I found a shop that passed my truck. And in the unlikely event you've seen the inaugural fte missouri chapter truck of the month, I'm pretty sure you'd know that the inspection was a ringer.
__________________
  #9 (permalink)
Old 10-16-2006, 06:56 PM
Quote:
Me, I thought for sure you would have a long list of places to go.
__________________
  #10 (permalink)
Old 10-16-2006, 07:07 PM
tcbofade's Avatar
1986 Ford F-150
I'll bet you a nickel that he's got a short list of where you can go...
__________________
  #11 (permalink)
Old 10-16-2006, 07:32 PM
Thank's for running interference Terry, he left himself wide open for that one. BTW, you're correct on the length of that list...
  #12 (permalink)
Old 10-16-2006, 09:05 PM
bobf100's Avatar
bobf100 bobf100 is offline
bobf100 is starting off with a positive reputation.
Not sure what year truck that you need the inspection but if the truck is over 25 years old there is a special provision in the Missouri historical plate statute that allows you to use a plate from the same year that the truck was manufactured. If you can find one and nobody is currently using that plate number they will reactivate that plate.
My F100 is a 1956 so I found a Missouri 56 truck plate on Ebay for $10. The State ran the numbers thru the system and found nobody currently using that particular number so they reactivated that plate. The beauty of the system is that there is no yearly inspection and no yearly smog inspection required. There is no renewal fee either - pay $25 up front and the plate is good for as long as you own the vehicle. The down side is that you need to keep a mileage log in the vehicle in case Missouri's finest stop you.
  #13 (permalink)
Old 10-16-2006, 09:12 PM
the truck is an 84
so its 20 years old not old enough
  #14 (permalink)
Old 10-17-2006, 07:12 AM
fellro86's Avatar
fellro86 fellro86 is online now
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
If you can hold out for a few more months, as of the 1st of the year, no more inspections, but until then....
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #15 (permalink)
Old 10-17-2006, 07:25 AM
vloney vloney is offline
vloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to behold
thats what I like about FTE, Even though I'm an inspector, I never heard of that!
__________________
ase master tech--fmc senior master tech 92 4x4 ranger 4.0
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
