power windows wont work on all passenger doors.
hi i was wonderin if anyone has this problem. on all passenger doors they can not roll down their windows at all only from the drivers door. i made sure that the window locks wernt on and the problem still happens. could it be the switch and relay? also i have problems with the head lights too the dont automaticly come on anymore i have to manually turn them on. could this be cause i plugged in my stock trailer light wires? thanks
What year is it?
On a 97 red/light blue is connected to the lock switch and supplies voltage to the other door switches.
If this is a 97 check for a break in that wire in the drivers door jamb. |
hi sorry it's a 98 XLT. I noticed my tail lights dont work too it comes on then goes off sometimes it doesnt come on and it does come on then back off. i have to check for recall issues.
Have you checked to make sure the window lockout switch is not on? Try flipping it the other way and try again.
It is common on the 97-98 for the wires in the door jamb (large rubber connection ) to break, pull the lower boot back and check the wires by gently pulling on them, the broken ones will stretch. solder a piece of wire in between the broken ends and shrink wrap.
As for the Daylight running lights, there should be a module below the driver side headlight on the inside of the radiator support, the plug gets wet and corrodes, clean and you might fix the problem.. |
