power windows wont work on all passenger doors. - Ford Truck Enthusiasts Forums
Old 05-08-2006, 02:11 AM
contourfreak22 contourfreak22 is offline
contourfreak22 is starting off with a positive reputation.
hi i was wonderin if anyone has this problem. on all passenger doors they can not roll down their windows at all only from the drivers door. i made sure that the window locks wernt on and the problem still happens. could it be the switch and relay? also i have problems with the head lights too the dont automaticly come on anymore i have to manually turn them on. could this be cause i plugged in my stock trailer light wires? thanks
Old 05-08-2006, 05:54 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
What year is it?
Old 05-08-2006, 11:10 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
On a 97 red/light blue is connected to the lock switch and supplies voltage to the other door switches.
If this is a 97 check for a break in that wire in the drivers door jamb.
Old 05-09-2006, 01:54 AM
hi sorry it's a 98 XLT. I noticed my tail lights dont work too it comes on then goes off sometimes it doesnt come on and it does come on then back off. i have to check for recall issues.
Old 05-10-2006, 04:54 PM
bdmcdonald bdmcdonald is offline
bdmcdonald is starting off with a positive reputation.
Have you checked to make sure the window lockout switch is not on? Try flipping it the other way and try again.
Old 05-11-2006, 08:50 AM
Old 05-11-2006, 11:07 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
It is common on the 97-98 for the wires in the door jamb (large rubber connection ) to break, pull the lower boot back and check the wires by gently pulling on them, the broken ones will stretch. solder a piece of wire in between the broken ends and shrink wrap.
As for the Daylight running lights, there should be a module below the driver side headlight on the inside of the radiator support, the plug gets wet and corrodes, clean and you might fix the problem..
Power windows and 4wheel drive switch not working CWO-06250 1999 to 2016 Super Duty 5 02-16-2012 04:47 PM
2003 Explorer passenger front window will not close fosterslager Explorer, Sport Trac, Mountaineer & Aviator 1 01-08-2012 01:49 PM
Passenger window will not work from passenger door krehjc Paint & Bodywork 5 06-14-2011 06:42 PM
1996 Explorer Power window problem 00GT Explorer, Sport Trac, Mountaineer & Aviator 2 04-27-2007 12:34 PM
Need help with power window issue WXboy Ranger & B-Series 4 05-01-2003 09:23 PM
Tags
02, 06, 1995, 2001, dont, explorer, ford, mountaineer, passenger, power, rear, roll, windows, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
