EGR Removal - 351 5.8l V8 (H)
why would you want to? i blocked off the egr on a car i had and it didn't help at all. just made it run slightly hotter
you can remove the smog pump so long as you gut the cat so it dosnt clog. but blocking the egr is sort of a no no. it dosnt hurt the engine to have it on there it actualy helps it. gets the engine warmer when its cold and cools it down when its hot. it dosnt hurt your performance at all when under full throttle because the valve closes at that point anyway.
The reason I want to remove the egr system is because I hate the whole philosophy of it. To reintroduce exhaust gas into an engine is no good in my opinnion, plus i want to get rid of the air pump, which is just another aux. piece of crap in my way. I just like tinkering with stuff also.
Eric |
Thanks Sphinx-
For all the good information to help me complete this project. It's good to talk to someone else that has actually performed the task at hand!! Thanks again, Eric |
Not a problem I hate all the extra smog bs that you have to deal with these days too. Check out this website, this guy has a lot of info and hard to find parts for your project. http://fordfuelinjection.com/index.php?p=21
John |
