EGR Removal - 351 5.8l V8 (H) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-12-2006, 12:18 PM
eric.magnuson eric.magnuson is offline
eric.magnuson is starting off with a positive reputation.
Any Info would be helpful -
I own a 1997 Ford F-250HD with the 351 5.8L V8 engine. My question is reguarding the EGR system this engine has. Can you remove the EGR and all of its components including the air pump? If you can will you please give me any instructions or coaching.
Thanks,
Eric
Old 02-12-2006, 06:02 PM
liftmy250 liftmy250 is offline
liftmy250 is starting off with a positive reputation.
why would you want to? i blocked off the egr on a car i had and it didn't help at all. just made it run slightly hotter
Old 02-12-2006, 06:08 PM
BigRyanKP's Avatar
BigRyanKP BigRyanKP is offline
BigRyanKP is starting off with a positive reputation.
you can remove the smog pump so long as you gut the cat so it dosnt clog. but blocking the egr is sort of a no no. it dosnt hurt the engine to have it on there it actualy helps it. gets the engine warmer when its cold and cools it down when its hot. it dosnt hurt your performance at all when under full throttle because the valve closes at that point anyway.
Old 02-13-2006, 08:50 AM
The reason I want to remove the egr system is because I hate the whole philosophy of it. To reintroduce exhaust gas into an engine is no good in my opinnion, plus i want to get rid of the air pump, which is just another aux. piece of crap in my way. I just like tinkering with stuff also.
Eric
Old 02-13-2006, 08:54 AM
Thanks Sphinx-
For all the good information to help me complete this project. It's good to talk to someone else that has actually performed the task at hand!!
Thanks again,
Eric
Old 02-13-2006, 09:24 AM
sphinx's Avatar
sphinx sphinx is offline
sphinx is starting off with a positive reputation.
Not a problem I hate all the extra smog bs that you have to deal with these days too. Check out this website, this guy has a lot of info and hard to find parts for your project. http://fordfuelinjection.com/index.php?p=21
John
IDI versus Powerstroke MPG Riata_Ag Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 05-01-2006 05:54 PM
steering seems to be binding after lowering body davidsca 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-04-2006 07:49 AM
Ford axle code 47 ? 77Fordf100 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-02-2006 07:21 AM
Diesel envy-also posted in super duty forum terrapin88 1999 - 2003 7.3L Power Stroke Diesel 25 02-15-2006 07:08 PM
Running poorly in cold weather JDemo-in-NC Ford Inline Six, 200, 250, 4.9L / 300 3 12-30-2005 06:06 PM
Tags
1993, 1996, 351, 58l, air, block, egr, f350, ford, motor, pump, removal, removial, smog, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
