Is wvo safe for 89 f350?
does anyone know if wvo is safe to use in a 1989 F350 7.3L, as far as the seal, hoses and the ip goes. or the question that i should ask does the 89 diesels have natural rubber seal and hoses and more important does the ip's and injectors on the 89's use the natural rubber seal and o-ring. any info would be a great help. i plan on running my f350 on wvo soon, right now my taking stock on what all i need to deal with first. don't want to trash the motor.
thanks for the help -BR- |
I'm pretty sure WVO and rubber are fine together. It's when you start running biodiesel that you need to worry about rubber parts. I don;t know what year Ford stopped using rubber and went to other material
Erick Panger LESK WVO Conversions 2005 F250 PSD Plant Drive Two tank WVO system. Hotstk, Vormax, A1000 and Vegtherm |
https://www.ford-trucks.com/forums/s...d.php?t=436717
I think the link from cookie88 in post #4 will help you the most. -matt |
