Is wvo safe for 89 f350? - Ford Truck Enthusiasts Forums
Old 01-31-2006, 04:12 PM
BOB ROSS BOB ROSS is offline
BOB ROSS is starting off with a positive reputation.
does anyone know if wvo is safe to use in a 1989 F350 7.3L, as far as the seal, hoses and the ip goes. or the question that i should ask does the 89 diesels have natural rubber seal and hoses and more important does the ip's and injectors on the 89's use the natural rubber seal and o-ring. any info would be a great help. i plan on running my f350 on wvo soon, right now my taking stock on what all i need to deal with first. don't want to trash the motor.
thanks for the help -BR-
Old 01-31-2006, 09:10 PM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
I'm pretty sure WVO and rubber are fine together. It's when you start running biodiesel that you need to worry about rubber parts. I don;t know what year Ford stopped using rubber and went to other material
Erick Panger
LESK WVO Conversions
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000 and Vegtherm
Old 02-01-2006, 11:46 AM
woogs's Avatar
woogs woogs is offline
woogs is starting off with a positive reputation.
http://www.ford-trucks.com/forums/sh...d.php?t=436717
I think the link from cookie88 in post #4 will help you the most.
-matt
Another WVO question Bubba828 Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 04-01-2009 12:23 PM
mixing wvo ratio questions waltmiller222 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 04-07-2008 06:38 PM
hoses & seals ??? misnomer Bio-diesel, Propane & Alternative Diesel Engine Fuels 7 12-27-2007 03:26 PM
The pros and cons of homemade biodiesel vs wvo. derherr65 Bio-diesel, Propane & Alternative Diesel Engine Fuels 66 04-23-2007 09:23 AM
Svo/wvo on a road trip? Early death for IP? bio-d Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 08-04-2006 07:15 PM
Tags
1989, 73, 73l, 89, conversion, diesel, f350, ford, running, safe, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
