What does B5, B20, B100 mean?
I assume it means the percentage of biodiesel to dino fuel, but I thought you could run biodiesel straight? Why do some one person say they ran B50 fine, but had problems running B75? Are they talking about actual biodiesel, or mixing veggie oil with dino diesel?
Sorry for what might sound like dumb questions, but I am new to this biodiesel thing and am VERY interested in learning more about it before I try and run it. Thanks, Gary |
That is a good question. I'm interested in the answer myself.
Your assumption is correct about the fuel mixture designations. |
Thanks for the info.
I think I'm going to try some of the locally available B100 sold here in Tucson. I will try it straight and see what happens. I will just make sure to buy a couple of fuel filters first. |
Digracer, As I've told my military students years ago. "The only dumb question is the question not asked"
Ford says not to go over 5% bio or 5 gal of B100 for 95 gal of dino |
The number after B is the percentage of biodiesel blended with regualr diesel fuel; B20 - 20% bio, b100 - 100% bio.
As for the powerstroke be wary as Ford will not warrenty repairs if a part failes that is fuel related (injector, fuel pump, etc ) and the percentage of biodiesel is above 5%. I personally run B20 in a 2006 F250 without any problems in Florida. The powerstroke's injection pumps inject with tremendous preasure and can cause the biodiesel to polaramize at higher concentrations causing the injection pumps to fail. |
...Welcome gasboytgill, to Ford Truck Enthusiasts!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
To answer your question fully B means Bio, and the number after it means the amount in percent that is blended with Petroleum based Diesel. B20 has been tested thoroughly by the military and has shown no significant dissadvantages. Yellowstone National park in Wyoming has run B100 for years now in their equipment and had no problems until on very (-37 degree) night. Rudolph Diesel invented the Diesel Engine to run on Peanut oil (not good in cold weather) and we have butchered it so that reverse engineering needs to be done to get back to his roots. I do like the Idea of running on SVO, however I am against WVO because of the water and FFA (Free Fatty Acids) that can damage injectors and pumps, and making Biodiesel out of it instead eliminates, for the most part, those factors. I would be glad to have any discussion with anyone about Biodiesel at any time, and would be willing to travel a short distance from Southern NH to help anyone that needs it. Just PM me.
everyone here has given great answers. The #'s assumption is correct. As for the % of BD folks run with and what they say is problematic does depend upon how they drive, where, temps, and quality of the fuel. I brew my own BD at home and run B100 in both mine and Momma's PSD's. I have had no issues related to the fuel or fuel systems. I have run blends again with no issues. I have however run commercially made fuel, and also quality tested it alongside my home brew. Honestly my home brew is cleaner and better quality with a lower cloud point then the ASTM commercial fuel. So my guess could be they have purchased and run lower quality fuels or even had bad petroleum diesel(PD) in their blends and they blame the BD for the problem. Just a guess but thats my answer
Fire rooster Remember this is big oil trying to keep it's foothold, and Bio threatens it. Keep your friends close and your enemies closer. I would bet they will stop at nothing to discredit Biodiesel. JMHO
