1994 Ford Ranger Starting Problems
I have a 1994 Ford Ranger 2-wheel drive 4 cylinder standard 5-speed. I've had intermittent starting problems. I have just changed out the starter (Sat), and it's still doing it. In fact it was worse tonight, it never started back up without a push. It attempts to start for about a second, then the power cuts out like the battery has gone dead and all the gages go back to zero. Tonight I noticed my clock reset back to 12:00 like as if I disconnected the battery. My starter has the cylinoid(sp) attached to it. I'm lost have no idea what the problem could be, any advice would be appreciated.
Thanks!! |
Run this ride by your favorite autoparts store for a electrical system check up via their portable system tester. It'll likely sniff out the problem.
The clock thing, makes me suspect a battery, battery cable, contact, or ground problem. |
Thanks PawPaw
It was corroded battery cables. Thanks for your imput, it's greatly appreciated! I'm back on the road again!
Good find, fix & feedback Tigercub, good to hear you're "on the road again". lol
