1994 Ford Ranger Starting Problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-25-2005, 11:31 PM
Tigercub Tigercub is offline
Tigercub is starting off with a positive reputation.
Question 1994 Ford Ranger Starting Problems
I have a 1994 Ford Ranger 2-wheel drive 4 cylinder standard 5-speed. I've had intermittent starting problems. I have just changed out the starter (Sat), and it's still doing it. In fact it was worse tonight, it never started back up without a push. It attempts to start for about a second, then the power cuts out like the battery has gone dead and all the gages go back to zero. Tonight I noticed my clock reset back to 12:00 like as if I disconnected the battery. My starter has the cylinoid(sp) attached to it. I'm lost have no idea what the problem could be, any advice would be appreciated.
Thanks!!
Old 07-26-2005, 09:04 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Run this ride by your favorite autoparts store for a electrical system check up via their portable system tester. It'll likely sniff out the problem.
The clock thing, makes me suspect a battery, battery cable, contact, or ground problem.
Old 07-26-2005, 09:46 PM
Thumbs up Thanks PawPaw
It was corroded battery cables. Thanks for your imput, it's greatly appreciated! I'm back on the road again!
Old 07-26-2005, 10:01 PM
Good find, fix & feedback Tigercub, good to hear you're "on the road again". lol
1990 Ranger wont/hard start when cold.... 64blueblood Ranger & B-Series 14 11-27-2014 11:30 AM
1994 Ford F 150 starter issues Shawn Hines 1987 - 1996 F150 & Larger F-Series Trucks 2 08-31-2012 10:11 PM
94 Ranger Starting Problems jrinaldi82 Ranger & B-Series 1 02-03-2011 02:46 AM
1994 f-350 starter problems rangermann17 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-20-2009 04:08 PM
1994 f150 starting problem pete m 1987 - 1996 F150 & Larger F-Series Trucks 2 06-26-2002 11:45 AM
Tags
1994, 94, ford, problem, problems, ranger, starter, starting, troubleshoot, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
