Hi guys :) After trying to get my front 2001 Lincoln Nav rotor off a couple of days ago, with no luck, i decided to search the car/truck forums, in hopes that someone had gone through this already, and had found an easy trick to removing them. I read every post in this thread, and tried ALL tricks: gear/pulley remover, two bolts through caliper anchor holes, 3 lb. sledge, and even tried using heat from cutting torch......nada. Also tried sawzall, but it cut in about 1/2", and stopped. Thought blade dulled, so inserted new one, and it made no more head way. My last, and final attempt worked. I used my grinder with cutting wheel, cut through to hub, and just sliced into center area a little, as to not cut into hub. Then i cut a wedge in front edge of rotor, inserted large flat chisel, hit 3 times with 3 lb. sledge, rotor split apart, and old @#T&*^$# rotor slipped right off. When i did second front rotor, i by passed all of above, except cut off wheel, and had that one off in about 1/2 hr., compared to about 3 hrs. on first one. Thanks for all the tips guys, and i hope my experience, and solution, will help someone else. Good forum guys.....i registered, and book marked it :)
I Think there are 2 key things when using the bolt method: Spraying with pb blaster and putting the wheels back on, not tight and then backing with the car on the ground and breaking them loose.
But, each will have a divverent experience and method. |
I use a 16 lb. long handle sledge to get them off but then smear the hub center hole with anit-seize to make it easier next time.
Originally Posted by 903ASP
(Post 11610460)
(Post 11610460)
Originally Posted by digitalshooter
(Post 11611942)
But, each will have a divverent experience and method. Something to consider in the future tho :) |
Originally Posted by kidzstang
(Post 11612313)
Originally Posted by Man_tlac83
(Post 11613155)
I may have to try that myself and see what results I get. I am ready to just skip all this and just get a new hub and rotors, since neither has been changed since I got the vehicle and god knows if the hubs are originals are not. Not sure....
(Post 11613233)
I'd try Digitals, or my idea first Man, hubs will surely add a lot more expense to the job. Good luck my man.......no pun intended....lol
Oh I have. I've sprayed and waited, tightened bolts and beat on it like it stole money from my grandmother and my kids college funds. Then rotated a the rotor a little and repeated the steps. Used all kinds of different size hammers & pulleys. I didn't just myself with fire, but there is always a first time for everything. }> Already need driver rotor and at this point, I rather have good new parts on the front and not go back in for a little bit. |
(Post 11613745)
I'm not sure what size it is either, but around 3 clock pm eastern time that 's what I did. I was like screw it, it's all coming off. Especially since the hub is nicely rusted to the knuckle too :-arrgh. Steering Knuckle, hub and rotor are well mated to one another, a real screwed up 3some. Depending how this week goes I may take a shot at saving the knuckle. Don't want to replace all that and if I can save the hub that will be a plus as well.
(Post 11614982)
Nope I can't, luckly for this truck I love it. But love can go as fast as it can come. For what ever reason I am kind of enjoying myself. I am updating my post now if you want to see what my lower ball joint looked/looks like.
https://www.ford-trucks.com/forums/1...snapped-2.html |
(Post 11615091)
(Post 11617521)
WOW!!! I've changed quite a few ball joints in my day, and at the worst, they were sloppy, but i've never seen one broke? What were you doing? A little "Off road rock climbing" ?........lol
Stuck rotor here too!! I was using the bolt and nut to put pressure on the rotor, but that doesn't work.. At least on this '01 Expedition.. After reading this complete thread, I see people are cutting their rotors off. I don't have a sawzall, but I do have a 3" cutoff wheel. I'm guessing I can use it instead of a sawzall, but I need better instructions and picture would be best.
I keep seeing pie cut, when I read about the sawzall method. What am I suppose to do? Do I cut a pie slice shaped wedge from the outer rotor edge to the outer edge of the hub (The rotor would look like it had teeth like a gear) or and I just cutting the surface of the rotor, to the center then trying to crack it with a wedge? Pictures or a youtube video on the sawzall method please....... |
