1976 Ford Ranchero GT 'Ignition Switch?'
Does anyone know where the Ignition Switch is on a 76' Ford Ranchero GT??? And if so, how do you remove it and install a new one?Wendy67
its on the top of the steering column. you have to un-bolt the column, and lower it to gain access to it. 45 minute job max.
Thank You! 8D
Ignition switch??
Hi Wendy...
Your question is interesting to say the least... as is the answer that was given... All Fords have had their ignition switches on the steering column for close to 30years....It is the think you insert the key into an turn to start the car.. To remove the cylinder, which is what the key goes into insert the key, turn key forward to the first stop, then with a very narrow\thin screw driver or other tool, insert it into the very small hole just under the cylinder push up and then pull the ignition out.... Good idea to clean out the cylinder and spay with either WD40 or a graphite to keep it lubricated.. Best |
Wendy:
Has your ignition problem been identified?? One very common problem with the Rancheros and perhaps other Fords is that the "key" does not return to the "run" position after the engine starts. The problem is most likely in the lock cylinder and that can be cured per the message from Sandoc. The lock cylinder and the ignition switch are two separate items but they are conncected by a small rod which is slightly larger than the lead in a wooden pencil. The second likely problem is this rod which could be rubbing the top of the steering column. |
