Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-04-2004, 01:52 PM
Wendy67 Wendy67 is offline
Garage is empty, add now
Wendy67 is starting off with a positive reputation.
Question 1976 Ford Ranchero GT 'Ignition Switch?'
Does anyone know where the Ignition Switch is on a 76' Ford Ranchero GT??? And if so, how do you remove it and install a new one?Wendy67
  #2 (permalink)
Old 12-04-2004, 06:00 PM
whd507 whd507 is offline
whd507 is starting off with a positive reputation.
its on the top of the steering column. you have to un-bolt the column, and lower it to gain access to it. 45 minute job max.
__________________
1994 Bronco, 1996 Bronco, 1996 F-250 Powerstroke Supercab 4x4, 1979 F-600 Crewcab,1976 F-250CS, 2003 Mercury Marauder and assorted other boring vehicles...
  #3 (permalink)
Old 12-05-2004, 07:47 PM
Thumbs up 76' Ford Ranchero GT
Thank You!
  #4 (permalink)
Old 12-15-2004, 10:43 PM
Sanddoc Sanddoc is offline
Sanddoc is starting off with a positive reputation.
Ignition switch??
Hi Wendy...
Your question is interesting to say the least...
as is the answer that was given...
All Fords have had their ignition switches on the
steering column for close to 30years....It is the think you
insert the key into an turn to start the car..
To remove the cylinder, which is what the key goes into
insert the key, turn key forward to the first stop, then with a very
narrow\thin screw driver or other tool, insert it into the very small
hole just under the cylinder push up and then pull the ignition
out....
Good idea to clean out the cylinder and spay with either
WD40 or a graphite to keep it lubricated..
Best
  #5 (permalink)
Old 12-15-2004, 10:58 PM
JimR500 JimR500 is offline
JimR500 is starting off with a positive reputation.
Wendy:
Has your ignition problem been identified?? One very common problem with the Rancheros and perhaps other Fords is that the "key" does not return to the "run" position after the engine starts. The problem is most likely in the lock cylinder and that can be cured per the message from Sandoc. The lock cylinder and the ignition switch are two separate items but they are conncected by a small rod which is slightly larger than the lead in a wooden pencil. The second likely problem is this rod which could be rubbing the top of the steering column.
Tags
1976, 1977, 1979, 67, 76, ford, gt, ignition, info, key, problem, problems, problen, ranchero, removal, remove, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
