when I jumped the switch, yes it stayed on, same as when I jumped from the batt. to the electric clutch connector
If you jumpped the pressure switch and the compressor stayed on, but you are getting a pressure of 45 psi at the low side, you probably have too much pressure, which will also kick off the compressor in order to keep from blowing out a hose or seals...or the compressor itself. You really need to get some high side readings, that will tell us more. To do that, you need a full A/C gauge set, not just the little low side gauge. Maybe a trip to a shop is in order. Here is a link to an A/C forum that has helped me a lot. -TD
http://www.ackits.com/forum/categori...id=2&zb=622553 |
Ac Prblms
thanks for the link,
The can that I used..obviously had the low side gauge...45psi is the max on its little "chart" they have to let you know if its full or over..or even dangerously over. @ first I had it in the middle of this little chart...about 30...nothing. put more in..to about 40..still...nothing...@ about 43-48 psi...the clutch for the AC kicked on...and it started to cycle..but it didnt get cold.:confused: and when it did cycle...it was cycling the system rather quickly I dont know...I think I will just leave it for now..and deal with it next summer |
it will cycle
it'll do that until it maintains the pressure. urs should take about 3 cans. it'll tell you under the hood in most cases. son's 89 took 3 1/2 too blow cold.
Ac Cycles but now leaks down
It cycles, but now I think I have a very slow leak. Cause now..it wouldnt kick on till I added more...
I guess I will try and change the hoses out and the intercooler to see if that helps fix the leak..and I will purchase some more new O-rings as well whats the best way to lube O-rings for ac units? some lite 3-in one oil? Librac23 |
Info under hood
3.5 cans you say?....Hmmmm will have to check into that...and where under the hood will it tell me?
Leak down Testing
well. I live in North West Minnesota...it can get rather humid....and that all depends on the day. but thats anywhere really...LOL
But thank you for that tidbit...it was quite informative...I forgot about having the system evacuated...and yeah..I am all to familliar with the special green O rings....a little on the spendy side... But since I only replaced the canister..and Pump orings and didnt even crack open the lines between the cooler and the rest of the system...is it still a good chance there is a leak there? Cause I dont know if the system has ever been opened....cause I bought the truck used...and even then it didnt work SO...I will have a tech do the evacuation test...I'm quite sure there is a crack somewhere. Thanks again |
1999 f 250 t diesel
my ac blows hot when i idle or decelerate. sometimes on the open road. how do i fine tune it to stay working more reliably?
Started truck . turned ac on .came back five min later . ac was blowing hot air , smelled something funny ,turned off motor poped hood saw a faint trail of smoke comming from area around compressor , had wife cycle control on and off while watching clutch and it does not seem to turn very fast. left it alone put a large can of 134 in and it slowly stated coming back. drove home from lake havasu and it worked fairly well , then today on a short trip it started to blow cold then hot then had the funny skunk smell again. any ideas ? 2005 6.0 psd excursion
