Electronic fuel pump
Where can I find info on converting a flathead 239 to an electronic fuel pump?
I have a electric pump fitted in line by a previous owner
If you are running a original carb' you will need to drop the pressure to 4psi any carb shop should be able to supply a pressure reducer The previous owner just removed the mechanical pump and push rod and made a cover plate for the hole I have read discussions on other lists about losing oil pressure when removing the push rod but my engine runs with good oil pressure and no push rod Hope this helps Stephen |
