Electronic fuel pump - Ford Truck Enthusiasts Forums
Old 08-10-2004, 02:06 PM
skeleton33 skeleton33 is offline
skeleton33 is starting off with a positive reputation.
Where can I find info on converting a flathead 239 to an electronic fuel pump?
Old 08-10-2004, 05:24 PM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
I have a electric pump fitted in line by a previous owner
If you are running a original carb' you will need to drop the pressure to 4psi any carb shop should be able to supply a pressure reducer
The previous owner just removed the mechanical pump and push rod and made a cover plate for the hole
I have read discussions on other lists about losing oil pressure when removing the push rod but my engine runs with good oil pressure and no push rod
Hope this helps
Stephen
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
