Help on installing Sunpro gauges
I need some technical information on how to install and connect an older Sunpro tripple gauge (mechanical with needle indicators) system on a 1999 2WD Ranger, manual transmission and a 2.5L engine.
a. How and where do I tap into the oil system to connect the oil pressure gauge? I need to know where the oil sending unit is located, what the thread size is and can I put a tee on it to connect it to my mechanical gauge. b. How and where do I tap into the electrical system to connect the amp gauge? c. How and where do I tap into the coolant system to connect the temperature probe and gauge? I also need to know if there is another place on the engine that I can install the temperature bulb for the gauge. I can not disturb the original temperature sensor. This gauge pack is new and was given to me without any installation instructions from a friend who has since moved. |
