Help on installing Sunpro gauges - Ford Truck Enthusiasts Forums
Old 04-25-2004, 10:26 AM
kenwood599 kenwood599 is offline
kenwood599 is starting off with a positive reputation.
Question Help on installing Sunpro gauges
I need some technical information on how to install and connect an older Sunpro tripple gauge (mechanical with needle indicators) system on a 1999 2WD Ranger, manual transmission and a 2.5L engine.
a. How and where do I tap into the oil system to connect the oil pressure gauge? I need to know where the oil sending unit is located, what the thread size is and can I put a tee on it to connect it to my mechanical gauge.
b. How and where do I tap into the electrical system to connect the amp gauge?
c. How and where do I tap into the coolant system to connect the temperature probe and gauge? I also need to know if there is another place on the engine that I can install the temperature bulb for the gauge. I can not disturb the original temperature sensor.
This gauge pack is new and was given to me without any installation instructions from a friend who has since moved.
Water,oil, and volt mechanical gauges bigcountry62 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-22-2013 10:27 AM
Re connecting temp and oil pressure gauges shammon2 1967 - 1972 F-100 & Larger F-Series Trucks 2 02-27-2011 09:52 AM
oil pressure gauge not working NW 150 Electrical Systems/Wiring 5 09-12-2010 01:29 PM
Multiple Gauge Dash Mount Kit Freaksh0w 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 10-19-2009 09:48 AM
temp gauge 7278ford 1978 - 1996 Big Bronco 8 04-30-2009 08:26 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
88, amp, bronco, connect, ford, gauge, gauges, guide, install, installation, installing, manual, sunpro, v8, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
