25 inchs lift kit
Silver,
I never received your e-mail. Anyhow, no problem lifting the dually. But here is the tough question..... What tires do you plan on running under this lift? Being a dually you are limited on what you can do without relocating your rear springs, narrowing the rear axle, and resorting to custom built wheels all of which gets very expensive. }> If your truck was a SRW just about anything goes, but a dually is a whole different story. For this reason we generally stick to 37-38s with 8" lifts on these. But anything is possible. FWIW, I plan on selling the entire drive train out from under my X (only 20" lift) soon. This includes springs, hangers, shocks, gusseted axles with 5.13 gears, drive shafts, crossover steering, wheels, tires, etc.. I'd make you a hell of a package deal. :-X04 |
25 inchs lift kit
Originally posted by cwb O-kill, I am almost afraid to ask but what will you be replacing your suspension with? Parts list: Front ASS 36" Spring Hangers ASS 36" Cast Aluminum Blocks ASS 24" Drag Link Adjuster Sleeve ASS 2" Add-a-Leaf ASS 72" Lengthened Sway Bar Links ASS Quad CV ABS Plastic Front Driveline w/Carrier Bearing ASS Air Assist Steering (Dual Opposing Air Bags) ASS 48" Travel Pogo Shocks (6 per corner) ASS OE Brake Line Relocation Kit Rear ASS 28" Coil Sprung Spring Hangers (6" travel) ASS 36" Cast Aluminum Blocks ASS Overload Springs (12) ASS Right Angle Drive Dual CV Rear Driveline (Prototype) ASS 96" Hinged (Scissor Type) Traction Bars ASS 48" Travel Pogo Shocks (4 per corner) ASS OE Brake Line Relocation Kit The only details left to work out are how to mount the 74" DOT approved Michelin tires and we are still trying to get Weld to give us a break on the 32x36 aluminum wheels (with simulated beadlocks). :-X10 BTW, great thread. Thanks Silver! :-X05 |
25 inchs lift kit
