Rust Areas
Where are the rust areas to check for on a 96 bronco?
Aside from the typical suspension areas and the tailgate, any places that are easy to miss? |
The rear most body crossmember under the tail gate. also the rear corners of the floor and bottom of the tailgate
fender wells, rocker panel, muffler cover, muffler. door panels,
The paint peeled off the hood and now the hood is rusted, I just call the look "Patina, you can't buy that kind of look it has to be earned" |
-Rear quarters above the rear wheels, and back near the bumper
-Inner rear wheel wells -Bottom edge of tailgate -Rear-most crossmember as mentioned -Radiator support at the bottom where it bolts to the frame -Bottom of B-pillars near rocker panels -Bottom of front fenders just behind front wheels -Rear leaf spring shackles and hangers |
my 96' rusted bad in the cowl area under the driver side wiper due to clogged cowl drain on the driver side.
Originally Posted by exranger06
(Post 16879089)
-Inner rear wheel wells -Bottom edge of tailgate -Rear-most crossmember as mentioned -Radiator support at the bottom where it bolts to the frame -Bottom of B-pillars near rocker panels -Bottom of front fenders just behind front wheels -Rear leaf spring shackles and hangers Late to the party. Were you looking at buying one and did you? |
