Rust Areas - Ford Truck Enthusiasts Forums
Rust Areas
Old 01-03-2017, 06:52 PM
para para is offline
para is starting off with a positive reputation.
Rust Areas
Where are the rust areas to check for on a 96 bronco?
Aside from the typical suspension areas and the tailgate, any places that are easy to miss?
Old 01-06-2017, 03:07 AM
hivoltj's Avatar
hivoltj hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
The rear most body crossmember under the tail gate. also the rear corners of the floor and bottom of the tailgate
Old 01-15-2017, 04:38 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
fender wells, rocker panel, muffler cover, muffler. door panels,
The paint peeled off the hood and now the hood is rusted, I just call the look "Patina, you can't buy that kind of look it has to be earned"
Old 01-18-2017, 10:25 AM
exranger06 exranger06 is offline
exranger06 is starting off with a positive reputation.
-Rear quarters above the rear wheels, and back near the bumper
-Inner rear wheel wells
-Bottom edge of tailgate
-Rear-most crossmember as mentioned
-Radiator support at the bottom where it bolts to the frame
-Bottom of B-pillars near rocker panels
-Bottom of front fenders just behind front wheels
-Rear leaf spring shackles and hangers
Old 02-15-2017, 07:54 PM
Biscayne Biscayne is offline
Biscayne is starting off with a positive reputation.
my 96' rusted bad in the cowl area under the driver side wiper due to clogged cowl drain on the driver side.
RUST....need advice filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-13-2016 11:53 PM
Dually Owners - rust around dually fender? MDSuperDuty 1999 to 2016 Super Duty 4 10-24-2015 10:25 AM
Where to find Ospho in KC Area Woodyp Kansas Chapter 6 01-07-2012 08:07 PM
Rear Frame Rust Repair shelby987 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-25-2006 11:28 AM
Rust Behind Cab Corners CollinsCD Paint & Bodywork 5 07-23-2002 12:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
