boost
I ordered a CX racing T3/T4 turbo with 12 psi internal wastegate what all do i need to put it on my 2.3 ranger motor?
Boost parts
Manifold
Pipes Cooler Blow off valve Wideband o2 Tuner Gauges Injectors oil lines Pistons Rods Rings You can only run 5-8 psi on stock internals without detonation and cracking the cast pistons. It's been a while since you posted this, if you have gotten it on already how is it? |
