King Ranch seats in an OBS
Has anyone put these in?
I've read about you guys doing the superduty seats, were those easy to mount. I bought some King ranch seats with the center console I took some measrements and the brackets are def different, at first glsnce it looks like I may modify the seat bracket and/or modify the body. Also I have the red interior so I painted the tan on the center console red and the brown plastic on the seats red to better match the interior, will have pics later this week |
In general I think that most guys mount the SD seats to the OBS seat bracket (pan) in the front. In the rear you don't have the pan, so most guys end up fastening the seats directly to the floor. I looked at Bill's a few weeks back and that's how his were anyway...
Originally Posted by DIYMechanic
(Post 14611703)
The SD seats in my OBS are all bolted directly to the floor. I used some pretty good sized washers to spread the load around in case I ever do wreck it, but thankfully I haven't had to test that. LOL. On the passenger side I had to space up the side closest to the door about an inch b/c of the way the transmission tunnel is and how the center seat sits.
Originally Posted by fordpride
(Post 14611776)
Here ya go
How To: Install Super Duty King Ranch Seats In A 94 Crewcab - Diesel Forum - TheDieselStop.com
Originally Posted by strokin'_tatsch
(Post 14611783)
Well there you go! I stand corrected. ;) |
(Post 14611776)
Here ya go
How To: Install Super Duty King Ranch Seats In A 94 Crewcab - Diesel Forum - TheDieselStop.com Thanks for the link, I have the same exact front setup, I am still looking for a rear seat though. I just took one of the seats to a leather guy cuz there is one tear in a wear spot which is why I got the deal i did. I'll have him repair that then install |
(Post 14611783)
I actually found your right up when you did yours I just didnt see pics of the finished product. Do you have that:-jammin |
I installed my front King Ranch seats today. Big upgrade. I sit a little higher which I like. I had to cut the front inside bracket off each seat and reweld them to contour the floor but still was painless. Drilled some holes and was done.
Im thinking of trying to find a seat cover that matches the king ranch seats for the rear bench. Does that exist? https://cimg2.ibsrv.net/gimg/www.for...1142a82723.jpg https://cimg1.ibsrv.net/gimg/www.for...a47faa0de2.jpg https://cimg9.ibsrv.net/gimg/www.for...a3ac240672.jpg |
I totally never saw your last post! Lol. I have a pic of my SD seats running around somewhere. Just don't remember where. Looks like you got it figured out though. Looks good.
(Post 14723819)
Originally Posted by jchosler
(Post 14724046)
No worries, I still need to get the seat belt worked out. What did you end up doing for that or did they both work with each other? My male wont fit into the female :-jammin |
Why not swap in the sd seatbelts?
It's easier to use the factory ends, but if you wanted to see if the SD parts would fit, that'd be alright too.
(Post 14724136)
I didn't use the SD female ends. I took those out and used the stock female ends. They just got pulled up between the seats and hang out there. Lol
I def saw that as an option, I wanted to see how hard it would be to swap the male ends. Not sure how that comes apart tho |
