engine Identity codes
I picked up a 63 F250 last week. the guy said it had an 87 Carbed V8 in it but didnt know where it came from or what size it was. where in the engine codes on the late 80s model V8s so I can figure this out.
I know how to decode it just not sure where to look for the numbers. Where did ford stamp the block/head on late 80s V8s
The block casting numbers are down on the side around where the starter mounts and the heads are on the bottom of one of the central intake ports so you can't see them unless the intake is off. And that's the good news unfortunately, casting numbers will only tell you the relative vintage of the parts it won't tell you what vehicle it came from, and there are no numbers that will tell you that but all is not lost as there really wasn't much difference between a car or truck engine from that era so the exact vehicle doesn't matter. As for exactly what engine you have that will have to be visually verified, it's most likely you have something from the Windsor family, if you can confirm that by the the shape and size of the valve covers and the location of the theremostat in the intake not the block, then figuring if it's a 302 or 351 just comes down to the width of the intake, about 6" is a 302 and somewhere around 9" is a 351.
post a picture of the engine. that alone is usually enough for us to id it.
Awesome thanks guys ill get a picture up today. I'm not worried about what vehicle it came from just want to know the size.
Originally Posted by Conanski
(Post 14591851)
The intake # is on the top of the manifold. The head #'s are inside the valve cover. |
alright here is the pictures of the engine, what is it?
http://i358.photobucket.com/albums/o...psoswesh3e.jpg http://i358.photobucket.com/albums/o...psqiadblcl.jpg |
Can't see the casting #'s… looks like a 460 to me.
The intake # will help… pull the air cleaner off and report back. That sticker on the valve cover should also tell you... |
Krooser I think you are correct on the 460 I looked on the sticker and couldnt find anything at first but right there at the bottom in small print it says 7.5L so i believe it is indeed the big boy.
http://i358.photobucket.com/albums/o...psqsfnfhaj.jpg http://i358.photobucket.com/albums/o...psw1hrf4jy.jpg secondly can anyone tell me what this is......and where I should attach it hahaha. I think its part of my heater http://i358.photobucket.com/albums/o...psqbyrtf8s.jpg |
Originally Posted by krooser
(Post 14593032)
The casting # will tell you the original application. :-huh look at the 3rd letter. That's the model…Galaxie, truck, Fairlane, etc.
For example: Casting number prefix: C6ME = FE engines installed in 1966 Ford/Merc cars and F100/350's. Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers. 460 block casting number prefixes: C8VE/C9VE/D0VE = 1968/70 429/460. 460 block casting numbers: D1VE-6015-AB, AB1, AB2 = Internally balanced = 1971/73 429, 1971/78 460, some 1979 460's (no 460's in cars after 1978). D9TE-6015-AB = Externally balanced, has a weighted spacer. Some 1979's, 1980/97. |
(Post 14593780)
:-missingt You cannot go by the 3rd digit, as it applies to myriad different vehicles.
For example: Casting number prefix: C6ME = FE engines installed in 1966 Ford/Merc cars and F100/350's. OP's casting number prefix could be E0AE which applies to cars, trucks, Bronco's and Econolines. Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers. 460 block casting numbers: D1VE-6015-AB = Internally balanced 1971/73 429, 1971/78 460, some 1979 460's (no 460's in cars after 1978). D9TE-6015-AB = Externally balanced, has a weighted spacer Some 1979's, 1980/97. If you find a "6" for a Pantera it would never have been used on an Econoline. But these#'s are all we have to get an ID on what the part was originally used on. They are used by Ford collectors who also use them to determine 'correct' parts for a restoration. They are not parts #'s but casting #'s… without them you have nothing. XXAX-XXXX-X Generic Full size ford XXCX-XXXX-X Remanufactured part 1966-1975 XXDX-XXXX-X Falcon/Maverick XXEX-XXXX-X Truck XXFX-XXXX-X Foreign or Trans Am racing XXGX-XXXX-X Comet 1961-1967 or Montego 1968-1976 XXHX-XXXX-X Holman Moody Hiperf parts or 1966-1982 Heavy truck XXJX-XXXX-X Industrial XXLX-XXXX-X Lincoln XXMX-XXXX-X Mercury XXOX-XXXX-X Fairlane(all) and Torino 1967-1976 XXSX-XXXX-X Thunderbird XXTX-XXXX-X Truck XXUX-XXXX-X Econoline Club Wagon Van XXVX-XXXX-X Lincoln XXWX-XXXX-X Cougar XXYX-XXXX-X Meteor 62-72 (Canada), Bobcat 75-81 XXZX-XXXX-X Mustang XX6X-XXXX-X Pantera |
These 3rd digits look like they came from the awful red book, a POS foisted on mankind...that claimed to decode casting & part number prefixes.
Uh huh, most of the info is BS! |
like I said i dont give a hoot what vehicle it came out of honestly I just wanna know what it is which I do its a 460 from a late 80s Ford whogivesacrap and now I can get parts for it if it ever dies.....Thank you FTE
