engine Identity codes - Ford Truck Enthusiasts Forums
Old 08-17-2014, 11:25 PM
roughridn_sob's Avatar
roughridn_sob roughridn_sob is offline
roughridn_sob is starting off with a positive reputation.
I picked up a 63 F250 last week. the guy said it had an 87 Carbed V8 in it but didnt know where it came from or what size it was. where in the engine codes on the late 80s model V8s so I can figure this out.
Old 08-17-2014, 11:58 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
Old 08-18-2014, 12:33 AM
I know how to decode it just not sure where to look for the numbers. Where did ford stamp the block/head on late 80s V8s
Old 08-18-2014, 01:45 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The block casting numbers are down on the side around where the starter mounts and the heads are on the bottom of one of the central intake ports so you can't see them unless the intake is off. And that's the good news unfortunately, casting numbers will only tell you the relative vintage of the parts it won't tell you what vehicle it came from, and there are no numbers that will tell you that but all is not lost as there really wasn't much difference between a car or truck engine from that era so the exact vehicle doesn't matter. As for exactly what engine you have that will have to be visually verified, it's most likely you have something from the Windsor family, if you can confirm that by the the shape and size of the valve covers and the location of the theremostat in the intake not the block, then figuring if it's a 302 or 351 just comes down to the width of the intake, about 6" is a 302 and somewhere around 9" is a 351.
Old 08-18-2014, 04:10 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
post a picture of the engine. that alone is usually enough for us to id it.
Old 08-18-2014, 11:21 AM
Awesome thanks guys ill get a picture up today. I'm not worried about what vehicle it came from just want to know the size.
Old 08-18-2014, 02:20 PM
krooser's Avatar
Quote:
The casting # will tell you the original application… look at the 3rd letter. That's the model…Galaxie, truck, Fairlane, etc.
The intake # is on the top of the manifold. The head #'s are inside the valve cover.
Old 08-18-2014, 06:39 PM
alright here is the pictures of the engine, what is it?
Old 08-18-2014, 06:57 PM
krooser's Avatar
Can't see the casting #'s… looks like a 460 to me.
The intake # will help… pull the air cleaner off and report back.
That sticker on the valve cover should also tell you...
Old 08-18-2014, 07:20 PM
Krooser I think you are correct on the 460 I looked on the sticker and couldnt find anything at first but right there at the bottom in small print it says 7.5L so i believe it is indeed the big boy.
secondly can anyone tell me what this is......and where I should attach it hahaha. I think its part of my heater
Old 08-18-2014, 07:29 PM
Old 08-18-2014, 07:35 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by krooser View Post
The casting # will tell you the original application. look at the 3rd letter. That's the model…Galaxie, truck, Fairlane, etc.
You cannot go by the 3rd digit, as it applies to myriad different vehicles.
For example: Casting number prefix: C6ME = FE engines installed in 1966 Ford/Merc cars and F100/350's.
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
460 block casting number prefixes: C8VE/C9VE/D0VE = 1968/70 429/460.
460 block casting numbers:
D1VE-6015-AB, AB1, AB2 = Internally balanced = 1971/73 429, 1971/78 460, some 1979 460's (no 460's in cars after 1978).
D9TE-6015-AB = Externally balanced, has a weighted spacer. Some 1979's, 1980/97.
Old 08-18-2014, 07:47 PM
krooser's Avatar
OP's casting number prefix could be E0AE which applies to cars, trucks, Bronco's and Econolines.
D1VE-6015-AB = Internally balanced 1971/73 429, 1971/78 460, some 1979 460's (no 460's in cars after 1978).
D9TE-6015-AB = Externally balanced, has a weighted spacer Some 1979's, 1980/97.
Some do… some don't.
If you find a "6" for a Pantera it would never have been used on an Econoline. But these#'s are all we have to get an ID on what the part was originally used on. They are used by Ford collectors who also use them to determine 'correct' parts for a restoration.
They are not parts #'s but casting #'s… without them you have nothing.
XXAX-XXXX-X
Generic Full size ford
XXCX-XXXX-X
Remanufactured part 1966-1975
XXDX-XXXX-X
Falcon/Maverick
XXEX-XXXX-X
Truck
XXFX-XXXX-X
Foreign or Trans Am racing
XXGX-XXXX-X
Comet 1961-1967 or Montego 1968-1976
XXHX-XXXX-X
Holman Moody Hiperf parts or 1966-1982 Heavy truck
XXJX-XXXX-X
Industrial
XXLX-XXXX-X
Lincoln
XXMX-XXXX-X
Mercury
XXOX-XXXX-X
Fairlane(all) and Torino 1967-1976
XXSX-XXXX-X
Thunderbird
XXTX-XXXX-X
Truck
XXUX-XXXX-X
Econoline Club Wagon Van
XXVX-XXXX-X
Lincoln
XXWX-XXXX-X
Cougar
XXYX-XXXX-X
Meteor 62-72 (Canada), Bobcat 75-81
XXZX-XXXX-X
Mustang
XX6X-XXXX-X
Pantera
Old 08-18-2014, 07:53 PM
These 3rd digits look like they came from the awful red book, a POS foisted on mankind...that claimed to decode casting & part number prefixes.
Uh huh, most of the info is BS!
Old 08-18-2014, 07:57 PM
like I said i dont give a hoot what vehicle it came out of honestly I just wanna know what it is which I do its a 460 from a late 80s Ford whogivesacrap and now I can get parts for it if it ever dies.....Thank you FTE
1998 Expedition Diagnostic code P0401 Insufficient EGR Flow JarrettCox Expedition & Navigator 21 02-20-2016 09:24 PM
V8 or V10? sqdqo 1999 to 2016 Super Duty 22 02-17-2016 11:15 AM
2000 Ford Expedition v8 p300 code Diver down Expedition & Navigator 6 01-03-2016 03:13 PM
p0340 code wtroger 1968-2013 Full Size Vans 1 06-27-2015 07:01 AM
From a V8 to V6 What the....? van_a_knockin 1968-2013 Full Size Vans 31 08-29-2014 05:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
