1950 F1 truck (o)
need some help with repairing floor.......previous owner did not cut out any of the rusted floor and did a poor job of patching over..........
..thanks for you help |
Pics would be a help. Replacement floor panels are one option.
Pics would be great!
It also depends on how you would like to do so. There are a couple of different methods! Anywhere from cutting, welding, grinding to rust encapsulators. |
It really depends upon the extent of the rust. Mine started out looking to be a simple patch job but it quickly became apparent that I needed to do it right and weld in new panels. Make sure that you remove some panels and the front fenders to decide which of these replacement panels you need.
Dennis Carpenter sells the full floor panel for $600 - a bit pricey and the back of my floor was in good condition. I got mine for $75 per side (front only) from Northern Classic Truck here in Michigan. They are only just across town so I saved the shipping too. https://cimg3.ibsrv.net/gimg/www.for...fe426f2059.jpg Left side after floor removal https://cimg9.ibsrv.net/gimg/www.for...b16b294ded.jpg Right side at A pillar had the worst rust https://cimg7.ibsrv.net/gimg/www.for...c1647f3d75.jpg Right side . . . you will need to trim the panels to fit your need. https://cimg2.ibsrv.net/gimg/www.for...2070e1e711.jpg And you may need to make some odd pieces to fit where the patch panel does not cover. Home Depot sells 1' or 2 ' sheet steel in 16 gauge. You may have to search through their stock as they usually only have the thinner 22 gauge in plentiful stock. https://cimg3.ibsrv.net/gimg/www.for...cb621ff373.jpg Dennis Carpenter full floor - $600 ! https://cimg9.ibsrv.net/gimg/www.for...c34375a6c6.jpg This is what I bought for $75 from Northern Classic Truck https://cimg0.ibsrv.net/gimg/www.for...74138c138f.jpg If your floor is gone along with the bottom of the A pillars you can buy this assembly from NCT but it is $470. In hindsight I might have been better off getting a pair of these. Check your truck carefully to see how far the rust has gone. A couple other tips:
