hpop questions
Hey I got questions on my truck I went out of town this weekend and pulled a trailer with a loader on it and when I got on it it will stumble I have a SCT tunner on it and was monitoring the data for fuel and what I found is my ICP requested and ICP pressures were right on if I didn't push hard but if I did it would request over 3300 it wouldn't match it and start the stumble it will not build over 3300 my ipr % would get to 83 and that's it so my question is do I have a bad pump or IPR valve? Or tune ? New to 6.0s but love this truck lol
Originally Posted by knutson28
(Post 14523657)
If you're running a tune then return it to stock and recheck the parameters. Tunes can sometimes alter ICP numbers to fool the PCM.
Its has 180xxx has 4 inch down 5 out other then the tunner stock and its 2003 I got it from a co worker when pulling his big camper it stall and not start wait 20 mins and off it goes till it stalled so I bought it knowing there was a issue I can't get it.to stall out and I can only get it to act up if I run a tune and its the can street tune he.never had the tunner in it I did that
(Post 14523925)
Another thing you need to check is fuel pressure, which will require a manual gauge.
I will check v koeo tonight but with it stock she will run about 3300 3200 psi but that's what it requested
(Post 14524466)
OK where do I check fuel pressure at and is it low side or high side I'm checking ? And. If I do have to do a pump do I go stock or is there anything better and thanks for the help guys
(Post 14524698)
(Post 14524698)
I think your going to do well and please keep us informed. Also Does the SCT allow you to look at all the data that the SGII does? ScanGaugeII : Linear Logic - Home of the ScanGauge Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
No I'm not using the SCT for data logging I have a snap on ethos I'm a diesel tech but I work at a kenworth dealer so don't see pickups lol but I have .19 volt koeo on ICP back to stock tune and used brakes driving down the highway to load it and it will request 3626 and it will stay pretty close I would say its +-25 psi and my inj% is 75-76% I will check what fuel pressure on the low side tonight
(Post 14526118)
a pain when it comes to diagnostics. Myself I have the SCT,SGII Snap-on Solus and IDS with VCM. Little bit of over kill. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
Lol in my world over kill is good when it comes to tools but I checked low side tonight and koeo it will go to 65 and start it stays at 65 went and beat the piss out of it still stayed at 65 -+5 psi so idk what is going on ..... i sure wish I could find something failed or failing so I can get it fixed lol
What or whose tunes are you running?
