hpop questions - Ford Truck Enthusiasts Forums
hpop questions
Old 07-21-2014, 02:17 PM
knutson28 knutson28 is offline
knutson28 is starting off with a positive reputation.
hpop questions
Hey I got questions on my truck I went out of town this weekend and pulled a trailer with a loader on it and when I got on it it will stumble I have a SCT tunner on it and was monitoring the data for fuel and what I found is my ICP requested and ICP pressures were right on if I didn't push hard but if I did it would request over 3300 it wouldn't match it and start the stumble it will not build over 3300 my ipr % would get to 83 and that's it so my question is do I have a bad pump or IPR valve? Or tune ? New to 6.0s but love this truck lol
Old 07-21-2014, 02:27 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Quote:
What year is your truck, miles and mods if any?
Old 07-21-2014, 03:06 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
If you're running a tune then return it to stock and recheck the parameters. Tunes can sometimes alter ICP numbers to fool the PCM.
Old 07-21-2014, 04:38 PM
Its has 180xxx has 4 inch down 5 out other then the tunner stock and its 2003 I got it from a co worker when pulling his big camper it stall and not start wait 20 mins and off it goes till it stalled so I bought it knowing there was a issue I can't get it.to stall out and I can only get it to act up if I run a tune and its the can street tune he.never had the tunner in it I did that
Old 07-21-2014, 05:26 PM
Return it to stock as previously mentioned and see if it still acts the same way under full throttle. What are the ICPV's at KOEO?
Old 07-21-2014, 05:31 PM
Another thing you need to check is fuel pressure, which will require a manual gauge.
Old 07-21-2014, 09:04 PM
I will check v koeo tonight but with it stock she will run about 3300 3200 psi but that's what it requested
Old 07-21-2014, 09:52 PM
Being an 03' the ICP is always suspect and so is the HPOP, but it is always good to know what the fuel pressure is.
Old 07-21-2014, 10:01 PM
OK where do I check fuel pressure at and is it low side or high side I'm checking ? And. If I do have to do a pump do I go stock or is there anything better and thanks for the help guys
Old 07-21-2014, 10:35 PM
I have heard a lot of good about the dieselsite HPOP and while more expensive than OEM they are much more reliable, the OEM remans are a crap shoot and guys have gotten them bad out of the box, http://www.dieselsite.com/2003-20046...lpumphpop.aspx If it were mine I would go with the slightly higher than stock output one.
Old 07-21-2014, 11:53 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Smart guy asking questions and listing to the advise given.
I think your going to do well and please keep us informed.
Also Does the SCT allow you to look at all the data that the
SGII does?
ScanGaugeII : Linear Logic - Home of the ScanGauge
Sean
Old 07-22-2014, 02:20 PM
No I'm not using the SCT for data logging I have a snap on ethos I'm a diesel tech but I work at a kenworth dealer so don't see pickups lol but I have .19 volt koeo on ICP back to stock tune and used brakes driving down the highway to load it and it will request 3626 and it will stay pretty close I would say its +-25 psi and my inj% is 75-76% I will check what fuel pressure on the low side tonight
Old 07-22-2014, 09:22 PM
Yahiko's Avatar
Having access to a good scan tool makes life so much less of
a pain when it comes to diagnostics.
Myself I have the SCT,SGII Snap-on Solus and IDS with VCM.
Little bit of over kill.
Sean
Old 07-22-2014, 11:30 PM
Lol in my world over kill is good when it comes to tools but I checked low side tonight and koeo it will go to 65 and start it stays at 65 went and beat the **** out of it still stayed at 65 -+5 psi so idk what is going on ..... i sure wish I could find something failed or failing so I can get it fixed lol
Old 07-23-2014, 06:27 AM
What or whose tunes are you running?
Somewhat low oil pressure. Bryishre 1999 - 2003 7.3L Power Stroke Diesel 5 02-22-2016 07:43 PM
94.5 HPOP pressure question wackercattle 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-09-2015 10:07 PM
missing on right bank no fire 6.0ford67 6.0L Power Stroke Diesel 12 12-05-2014 07:20 AM
P1211... ICP code EMD_DRIVER 1999 - 2003 7.3L Power Stroke Diesel 8 09-17-2014 04:59 PM
ICP/IPR question 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 7 08-01-2012 02:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
