Stroker kits 4.300 stroke 514 to 520" best kits?
Will be rebuilding my 460 and will be upgrading btm end. Looking in the 4.3 stroke or less. My truck gets driven on highway often for long distance so no big stroke engines. What's good what's bad is the question? Will
Be heavy truck 4wd application on 40" tires. |
Building a 521 for my truck project. 4.3 is a good stroke amount and you are correct would not want 4.5 for the street. You might still be able to find some deals on the old Ford kits, otherwise the SCAT type are good with the Chevy rod size. FYI 514 is standard bore and 521 is 30 over.
Go on over to 460Ford.com.....LOTS of info there.
Originally Posted by wyoming4x4
(Post 14521558)
