Stroker kits 4.300 stroke 514 to 520" best kits? - Ford Truck Enthusiasts Forums
Old 07-20-2014, 05:49 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
Will be rebuilding my 460 and will be upgrading btm end. Looking in the 4.3 stroke or less. My truck gets driven on highway often for long distance so no big stroke engines. What's good what's bad is the question? Will
Be heavy truck 4wd application on 40" tires.
Old 08-01-2014, 08:49 PM
cparks cparks is offline
cparks is starting off with a positive reputation.
Building a 521 for my truck project. 4.3 is a good stroke amount and you are correct would not want 4.5 for the street. You might still be able to find some deals on the old Ford kits, otherwise the SCAT type are good with the Chevy rod size. FYI 514 is standard bore and 521 is 30 over.
Old 08-19-2014, 12:53 AM
lance65's Avatar
lance65 lance65 is offline
lance65 is gaining momentum as a positive member of FTE.
Go on over to 460Ford.com.....LOTS of info there.
Old 09-02-2014, 05:30 PM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is offline
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
Make any decisions yet? I would like to pull my 460 and stroke this winter also using a 4.3 stroke kit. I think it will be the most bang for the buck at this altitude. Let me know how it turns out and if you used J Team.
410FE??? greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-03-2015 10:27 AM
How much 2 stroke A/Ox4 1999 - 2003 7.3L Power Stroke Diesel 50 08-05-2012 08:11 PM
tires on a dually 036.0stroke 1999 to 2016 Super Duty 12 01-29-2011 04:34 PM
434 vs 460 vs 514 AntiHero55 1973 - 1979 F-100 & Larger F-Series Trucks 14 11-11-2010 10:11 AM
Why would you De-stroke a truck engine? STGFordCrazy04 Performance & General Engine Building 26 09-13-2007 08:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
