You don't happen to have lift springs do ya?
Josh |
Ok here is a pic of me and the boy on it id say easy 380/400 lb. what do you guys think. Leave it be until she is all together?
http://imagizer.imageshack.us/v2/800...0/839/06gz.jpg |
Looks to me like you have big block springs, and a small block engine........
Seriously though, the springs may just be too long/stiff for the application. If they are new, they may need a bit of time to "settle", but that looks like a lot more than can be attributed to "settling" of the springs. |
Originally Posted by Rogue_Wulff
(Post 14377415)
Big block and small block springs do not make that much of a difference. Even moreso once the guys put their weight on it as in the demonstration.
Josh |
The vin says 302 I installed a 347 stroker with aluminum heads. The springs are the springs came with the truck.
Originally Posted by Bullitt390
(Post 14377483)
Josh |
Originally Posted by CDN Sharky
(Post 14377488)
I have another 1978 f100 I don't want to but maybe ill pull the springs of it and compare them. You guys think it makes a difference that the one im building is a 1978 1/2. is it possible the springs in there now are for a f150 that's heavier suspension right?
Originally Posted by redroad
(Post 14377497)
On my F350 dually it was 1" in height
Josh |
Ok there is 1 inch difference just measuring my parts truck is shorter it has in inline 6 in it. that could be it may have to switch them into it.
(Post 14377511)
Comparing an F350 dually to an F100?
Josh |
(Post 14377521)
(Post 14377535)
I'm comparing the difference in stock spring height in 2 motors only :-roll
Small block, around 450-500 lbs. Big block, 600+ |
So before doing all that work I loosend every bolt underneath drove the crap out of it on my gravel driveway and now it looks like the pic I have not tightend anything but I may be good now. Seems like it was stress on it after all.
http://imagizer.imageshack.us/v2/800.../843/87sza.jpg |
