Zejokee |
05-18-2014 05:33 PM |
Huge thanks to Anthony and Julie at SuperDutyService!!!
Just wanted to post my extremely positive experience with Super Duty Service in Grainvalley, MO. Had issues getting my truck running right after replacing the head gaskets myself. Had the issue narrowed down to the injectors/FICM/HPOP problem. But couldn't just throw parts at it without better diagnostics. Had my truck towed to SDS and got 8 new injectors and a FICM from Ed with Atlas 40. Started with a bad FICM and 4 injectors failing contribution / balance tests. Replaced those then the other 4 were weak / failing. Probably my fault on the injectors. I polished the spool valves with 1000 grit wet sand paper while they were out of my truck. If it ain't broke, don't fix it! Last time I try that trick on the injectors. The truck runs better than ever now!!! Anthony and Julie are amazing people and will do everything thing can to provide a great experience and get your truck back on the road. Everyone knows how much your wallet can take a hit when you have to repair your truck, let alone taking it to a shop. But I don't mind paying a shop when I know they are going to do great work on my truck and actually take pride in their work. I especially love the live stream they run so you can watch your truck being worked on! The customer service is top notch!!! Most shops close their doors at 5 and will not talk to you until business hours. Not SDS, if you need something, they are there! I will definitely consider taking my truck back if it is something I can't tackle my self or don't have time too. Anyone who is within a few hundred miles should check them out. It is worth the extra drive if you need work done to your truck.
Thanks again Anthony and Julie!!! :-jammin I am looking forward to the power rally!
