Ford Truck Enthusiasts Forums
-   1997 - 2003 F150 (https://www.ford-trucks.com/forums/forum25/)
-   -   Rear end interchange (https://www.ford-trucks.com/forums/1304838-rear-end-interchange.html)
andy_y 03-21-2014 06:14 PM
Hello all,
Been a while since I posted. Got my 53 Merc (06 ranger mechanicals) up and running last fall (see gallery for pics). Today my question is about my daily driver tho.
2002 F150 FX4. 232,000 km (140k miles approx). 3.55 limited slip 9.75". Rebuilt twice and just finished third seal change (replace bearing and front pinion seal plus fresh oil). Axles have deep grooves warn and I suspect that's what caused r.h. axle seal and subsequently replace bearing to fail after only a year and 25,000 km (15,000 miles). Time to find a whole new rear end assembly. My question is are later 04+ axles the same save spring and shock perches? I have the tools and know how to relocate and swap over perches if this is the case? My axle code is V919A and is a limited slip. I don't care about getting a limited slip only match ratio since its 4wd. Any advice is appreciated. Thanks
MJE426 03-21-2014 08:30 PM
Why not just get new axles?
steve(ill) 03-21-2014 09:39 PM
http://www.ebay.com/itm/Alloy-USA-Performance-Rear-Axle-Shaft-Ford-9-75-34-Spline-33-37-L-15145-/390802587007?pt=Motors_Car_Truck_Parts_Accessories&hash=item5afda63d7f&vxp=mtr#ht_1515wt_808
andy_y 03-21-2014 11:07 PM
Thanks for the response. That's a good idea I would have to get professional to measure the specs on the housing, gears, etc before I put more money in my housing. Not sure if its worth rebuilding again. Thanks once again!
BCHauler 03-22-2014 10:46 AM
97-03 are 5 lug and 04+ are 6 lug.
andy_y 03-22-2014 10:53 AM
Thanks for the heads up about later 6 lug axles. I think I may be able to get away with changing the axles as others suggested once the repair bearings fail again. Thanks to all for your input. Greatly appreciated!
