Rear end interchange - Ford Truck Enthusiasts Forums
Old 03-21-2014, 06:14 PM
andy_y andy_y is offline
andy_y is starting off with a positive reputation.
Hello all,
Been a while since I posted. Got my 53 Merc (06 ranger mechanicals) up and running last fall (see gallery for pics). Today my question is about my daily driver tho.
2002 F150 FX4. 232,000 km (140k miles approx). 3.55 limited slip 9.75". Rebuilt twice and just finished third seal change (replace bearing and front pinion seal plus fresh oil). Axles have deep grooves warn and I suspect that's what caused r.h. axle seal and subsequently replace bearing to fail after only a year and 25,000 km (15,000 miles). Time to find a whole new rear end assembly. My question is are later 04+ axles the same save spring and shock perches? I have the tools and know how to relocate and swap over perches if this is the case? My axle code is V919A and is a limited slip. I don't care about getting a limited slip only match ratio since its 4wd. Any advice is appreciated. Thanks
Old 03-21-2014, 08:30 PM
MJE426 MJE426 is offline
MJE426 is starting off with a positive reputation.
Why not just get new axles?
Old 03-21-2014, 09:39 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
http://www.ebay.com/itm/Alloy-USA-Performance-Rear-Axle-Shaft-Ford-9-75-34-Spline-33-37-L-15145-/390802587007?pt=Motors_Car_Truck_Parts_Accessories&hash=item5afda63d7f&vxp=mtr#ht_1515wt_808
Old 03-21-2014, 11:07 PM
Thanks for the response. That's a good idea I would have to get professional to measure the specs on the housing, gears, etc before I put more money in my housing. Not sure if its worth rebuilding again. Thanks once again!
Old 03-22-2014, 10:46 AM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
97-03 are 5 lug and 04+ are 6 lug.
Old 03-22-2014, 10:53 AM
Quote:
Thanks for the heads up about later 6 lug axles. I think I may be able to get away with changing the axles as others suggested once the repair bearings fail again. Thanks to all for your input. Greatly appreciated!
New bearings when installing true track differential? brada 1999 to 2016 Super Duty 11 01-08-2017 11:51 AM
1968 F100 Dana 60.3 Questions BuzzKing 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-10-2016 04:51 AM
Rear axle swap in Excursion, different lengths? blloyd29 1999 to 2016 Super Duty 1 03-28-2016 07:11 PM
Rear gear swapping with limited slip. wa-sleeper 1997 - 2003 F150 7 01-12-2016 08:21 PM
Rear axle play...what is normal? F150vettehauler 2004 - 2008 F150 3 05-21-2014 02:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
