Hey everybody, would like some idea what axle is installed if possible from the VIN. It has two sets of leaves in the back. Was that factory? Rides like a logging truck without some weight in back.
Edit. See that I posted this in the unibody forum, that nobody ever reads. Oh well. https://www.ford-trucks.com/forums/p...ctureid=151972 |
Originally Posted by Tedster9
(Post 14166903)
https://www.ford-trucks.com/forums/p...ctureid=151972 C = 292 2V K = Kansas City MO Assembly Plant. 558537 = 1964, assembled June 1964 (it's not a Uni). 128" Wheelbase. V = Academy Blue. F100 2WD, 5,000 lbs. GVWR 281: 2 = Medium Blue Crush Vinyl & Medium Blue Rib Vinyl // 81 = 81A Standard Cab. A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission. 11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity. 5,000 lbs. Gross Vehicle Weight Rating. 135 net HP @ 3,800 RPM 52 = Des Moines IA Ford District Sales Office, where the original selling dealer ordered the truck from. 1964 F100 2WD could have a 5 leaf spring pack w/a 950 lb. load rate or a 6 leaf spring pack w/a 1250 lb. load rate. An auxillary spring (1 leaf) was optional for both. The rear springs are the same 1957/67 F100 2WD, so there are other leaf spring packs that could be used. |
