VIN Help, axle and springs - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 03-15-2014, 04:15 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Hey everybody, would like some idea what axle is installed if possible from the VIN. It has two sets of leaves in the back. Was that factory? Rides like a logging truck without some weight in back.
Edit. See that I posted this in the unibody forum, that nobody ever reads. Oh well.
Old 03-31-2014, 03:03 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
F10 = F100 2WD
C = 292 2V
K = Kansas City MO Assembly Plant.
558537 = 1964, assembled June 1964 (it's not a Uni).
128" Wheelbase.
V = Academy Blue.
F100 2WD, 5,000 lbs. GVWR
281: 2 = Medium Blue Crush Vinyl & Medium Blue Rib Vinyl // 81 = 81A Standard Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
52 = Des Moines IA Ford District Sales Office, where the original selling dealer ordered the truck from.
1964 F100 2WD could have a 5 leaf spring pack w/a 950 lb. load rate or a 6 leaf spring pack w/a 1250 lb. load rate. An auxillary spring (1 leaf) was optional for both.
The rear springs are the same 1957/67 F100 2WD, so there are other leaf spring packs that could be used.
Vin Look up for a 1967 F100 theskytraveler 1967 - 1972 F-100 & Larger F-Series Trucks 8 11-08-2014 10:16 PM
1965 F600 VIN Decode crawlspeed Large Truck 7 06-12-2014 06:34 AM
VIN help, axle help, dual leafsprings Tedster9 1961 - 1966 F-100 & Larger F-Series Trucks 4 03-16-2014 08:52 AM
1959 F250 4x4 292 Project, Help with VIN Data Plate Decode and Missing Engine Dipstick/Tube alaskabarbie 1957 - 1960 F100 & Larger F-Series Trucks 13 02-15-2014 12:37 AM
VIN K vs. F oil filter difference? Catsailor Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 04-14-2008 08:39 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
