are all OBD codes the same no matter what vehicle the 5.4L is in??
(Yes I messed up its a 4.6L not a 5.4L)
I just bought a 2005 CVPI with 4.6L ( I asked in the crown Vic forums but not a lot of folks on that forum) seems to run great!! only codes I pulled are P061B and P2106 what are they? I guess they could be OLD CODES from a previous issue and were not erased.... are the codes engine or vehicle specific? any help would be great |
From the '05 PCED for the CV:
P061B - Internal Control Module Torque Calculation Performance Description: Indicates a calculation error occurred in the powertrain control module (PCM). This DTC is set in combination with P2106. Possible Causes: See the possible causes for DTC P2106. Diagnostic Aids: Application Key On Engine Off Key On Engine Running Continuous Memory All GO to QE1 . P2106 - Throttle Actuator Control (TAC) System - Forced Limited Power Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited power. This DTC indicates the FMEM action is in effect due to a failure in an electronic throttle control (ETC) related component or module. Possible Causes: Diagnostic Aids: This DTC is an informational DTC and may be set in combination with a number of other DTCs which are causing the FMEM. Diagnose other DTCs first. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to QE1 . If there are no current or known recent issues, reset the PCM and drive it normally to see if any faults return. |
So far so good.... the code must have been old codes, they have not returned
Try the Crownvic.net. I've been a member there for a couple of years now, it's a pretty good site.
