are all OBD codes the same no matter what vehicle the 5.4L is in?? - Ford Truck Enthusiasts Forums
Old 03-06-2014, 10:54 PM
Truckie256's Avatar
Truckie256 Truckie256 is offline
Truckie256 is gaining momentum as a positive member of FTE.
Question are all OBD codes the same no matter what vehicle the 5.4L is in??
(Yes I messed up its a 4.6L not a 5.4L)
I just bought a 2005 CVPI with 4.6L ( I asked in the crown Vic forums but not a lot of folks on that forum)
seems to run great!!
only codes I pulled are P061B and P2106 what are they?
I guess they could be OLD CODES from a previous issue and were not erased....
are the codes engine or vehicle specific?
any help would be great
Old 03-07-2014, 01:10 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
From the '05 PCED for the CV:
Quote:
P061B - Internal Control Module Torque Calculation Performance
Description: Indicates a calculation error occurred in the powertrain control module (PCM). This DTC is set in combination with P2106.
Possible Causes: See the possible causes for DTC P2106.
Diagnostic Aids:
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to QE1 .
Quote:
P2106 - Throttle Actuator Control (TAC) System - Forced Limited Power
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited power. This DTC indicates the FMEM action is in effect due to a failure in an electronic throttle control (ETC) related component or module.
Possible Causes:
Diagnostic Aids: This DTC is an informational DTC and may be set in combination with a number of other DTCs which are causing the FMEM. Diagnose other DTCs first.
All GO to QE1 .
If there are no current or known recent issues, reset the PCM and drive it normally to see if any faults return.
Old 03-12-2014, 07:51 PM
Truckie256's Avatar
So far so good.... the code must have been old codes, they have not returned
Old 03-18-2014, 01:29 AM
MJE426 MJE426 is offline
MJE426 is starting off with a positive reputation.
Try the Crownvic.net. I've been a member there for a couple of years now, it's a pretty good site.
4.6L to 5.4L kado7930 Engine Swaps 0 01-03-2016 12:46 AM
1998 F250 5.4L CEL Codes Belgar Modular V8 (4.6L, 5.4L) 4 01-10-2015 09:14 PM
P0401 code 1997 f150 4.6L W 174k 97f1504.6black 1997 - 2003 F150 4 04-25-2014 09:49 PM
5.4L 2v Intake Manifold Gaskets P0171 P0174 makuloco2000 1997 - 2003 F150 0 02-22-2014 05:40 PM
01 e250 p0171 & p0174 dafish13 1997 - 2003 F150 2 06-12-2012 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
