I will chime in with something about the cement mixer AND the flathead. I have owned tons of hit and miss (and throttle governed) one lung engines. In the late 80's I was given an 8 hp 1912 Stover engine. 6" bore, 12" stroke. I worked that out once and that's 327 cu in in one cylinder! This was my second engine of this vintage. When unsticking and disassembling it I found the bore to be quite pitted and boring was out of the question, as no oversize piston, no money (4 kids at home) for sleeving etc. I addressed my dilemma to a known expert in the field and he told me to hone what I could within reason and then proceded to tell me how he had built volkswagon racing engines for many years. He told me he used to mill 'pits' or dimples into the cylinder walls to hold oil, further lubricating the cylinder walls and rings. He suggested that my rust pits did no harm whatsoever, and the only problem would be a score or vertical groove (or series of connected pits). I have run the Stover at 75 rpms for 12 hours straight many many times. Also since then, I have left many rust pits in honed cylinders with great success. In my 20s, 30s and 40s I worried myself sick with agonizing over engine internals, but over the years I have relaxed a bit and think about what the people drove out west to escape the dust bowl. Heavily loaded, cheap or used oil etc etc. I admit I did plastigauge the bearings in the used 8ba I'm hoping to fire up this afternoon. Can you show some pictures of your bores?
That electrolysis is a pretty slick method for derusting stuff. Tried that on my fuel tank but it ended up freezing for me. There's just something about winter in MN. I guess.
Flathead pistons are available up to 3/16 inch oversize (final bore 3.375"). I don't recommend going that bit, but it is commonly accepted to be safe to bore a flathead 1/8 inch oversize (final bore 3.3125"). Post pictures of your cylinder walls and we can argue over whether you need a bore job or not. Keep the flathead.
More important, IMO, is clearance between the piston and bores. How much ridge? Also, what about ring groove wear, ring side clearance. Are there any vertical lines, cuts in the bore?
Like the 38 coupe man said, pictures for discussion. |
Thanks for the help!!!!!
got some pics for ya http://i973.photobucket.com/albums/a...r/_DSC0477.jpg http://i973.photobucket.com/albums/a...r/_DSC0479.jpg http://i973.photobucket.com/albums/a...r/_DSC0478.jpg http://i973.photobucket.com/albums/a...r/_DSC0475.jpg ..... Saveable?????.. GB SISSON, I love the sounds of those hit miss engines. and I really like your suggestions. The mixer was powered by a IH LA engine. I once refurbed a 1916 Economy 7 horse and traded it for this surface grinder.. http://i973.photobucket.com/albums/a...r/_DSC0484.jpg |
I had a 69 sportster that had some pitting in the ear cylinder and it smoked a little bit. Even a little bit more after doin' a nice smokey burn out. But it always ran strong.
Take a compression ring, fit it into the cylinder and push it down with the piston. Any catch at the pitting? Any catch with a fingernail? What is the ring gap, even top to bottom of travel? How about the ridge, catch it with a fingernail? Kinda hard to tell how deep the pitting is. Was the engine stuck when you got it, I forget? How about those two vertical scores in the cylinder, any catch with a fingernail? And again, what is the clearance between pistons and cylinder walls? What about ring land wear? If not excessive, I would almost go for a very light honing and go back together.
Yep she was stuck.
Rings are def. wore out. Gotta go to work now will check the other items when I have more time Thanks... ....Roger |
I am with Ray on this one. Give her a honing that will take out the ridge. (It doesn't look to deep). Than show us some pics of it again.
I think it will be just fine If the up down scratches mostly hone out. Them's the ones that could cause problems. Save the Flat Motor. But before getting any farther into it I would have it checked for cracks ya all can't see. |
Bore & hone - 8 cyl - $150
8 new pistons - $150 - $200 Rings - $90 Having an engine that runs like a top and doesn't smoke -- priceless.... Easier now than it ever will be, and IMO those cylinders are going to eat rings. PS -- have you had the engine thoroughly checked for cracks? I see the ones in the center bolt holes, those aren't a concern for a stock build. |
Good eyes Ross. I didn't see that crack till ya pointed it out. Ya say that
one won't cause any problems then? As I and Ross suggested it should be checked for cracks by a reputable crack checking shop thing before ya spend another dime on her. :-X22 |
Originally Posted by ALBUQ F-1
(Post 14147622)
That is a head bolt hole next to a water coolant passage. Common area for cracks. Use thread sealer. If I were going to pull the block and send it out, I would find oversize parts and have it bored, too. And then comes verification of hardened valve seats. Comes down to how much money, time and effort you want to spend and what you want when done. Either way, rebuild or patch, you'll have a 50 MPH vehicle.
It appears to have hardened seats. No question you're right about 50 mph, Ray, unless the usual swaps are made. And honestly, would anyone NOT do a valve job "while you're in there"? It's scope creep, something we're all familiar with.
Flatheads have a reputation as an expensive engine to rebuild. If you are in no rush you can drop the cost a lot by purchasing parts from other forum members, either here, on the Ford Barn, or on the HAMB. If it were mine and it passed crack check, I would probably bore to the next size pistons, refresh the bottom end and valve train, and have the rotating assembly balanced.
