5.4 v3 troubles please help
OK I had the engine rebuilt in this pig and need some help. It idles rough sounds like a diesel and is throwing PO340 PO345 AND PO349 codes the shop says they have triple checked timing and its correct he replaced bank 2 phaser crank position sensor and vct. Any suggestions?
Originally Posted by lawdog1973
(Post 14128325)
OK I had the engine rebuilt in this pig and need some help. It idles rough sounds like a diesel and is throwing PO340 PO345 AND PO349 codes the shop says they have triple checked timing and its correct he replaced bank 2 phaser and vct. Any suggestions?
Originally Posted by scubasteve728
(Post 14128333)
same thing happened to me this summer. ended up having to replace the engine. vct went and cam phasers were out of whack because the timing chain plastic guides broke and were chewed up into the engine and clogging sensors and oil wells thus loosing oil pressure.
(Post 14128345)
Mine has less then 100 miles on rebuild.
and check the oil level make sure is it not too low or high because it can cause it to throw those codes without the oil light on |
(Post 14128351)
what kind of oil and filter
