5.4 v3 troubles please help - Ford Truck Enthusiasts Forums
Old 03-03-2014, 04:31 PM
lawdog1973 lawdog1973 is offline
lawdog1973 is starting off with a positive reputation.
OK I had the engine rebuilt in this pig and need some help. It idles rough sounds like a diesel and is throwing PO340 PO345 AND PO349 codes the shop says they have triple checked timing and its correct he replaced bank 2 phaser crank position sensor and vct. Any suggestions?
Old 03-03-2014, 04:34 PM
scubasteve728's Avatar
scubasteve728 scubasteve728 is offline
scubasteve728 is starting off with a positive reputation.
Quote:
Originally Posted by lawdog1973 View Post
OK I had the engine rebuilt in this pig and need some help. It idles rough sounds like a diesel and is throwing PO340 PO345 AND PO349 codes the shop says they have triple checked timing and its correct he replaced bank 2 phaser and vct. Any suggestions?
same thing happened to me this summer. ended up having to replace the engine. vct went and cam phasers were out of whack because the timing chain plastic guides broke and were chewed up into the engine and clogging sensors and oil wells thus loosing oil pressure.
Old 03-03-2014, 04:38 PM
Quote:
Mine has less then 100 miles on rebuild.
Old 03-03-2014, 04:41 PM
what kind of oil and filter
and check the oil level make sure is it not too low or high because it can cause it to throw those codes without the oil light on
Old 03-03-2014, 04:48 PM
Just rechanged oil with OEM filter and 7 quarts of oil.
help needed tomeug69 Explorer, Sport Trac, Mountaineer & Aviator 2 12-10-2015 09:48 PM
PLEASE HELP....... milwaukee2000 1997 - 2003 F150 2 03-21-2015 07:12 PM
lots of codes help itsunday25 1994.5 - 1997 7.3L Power Stroke Diesel 4 07-07-2011 06:22 PM
Codes PO302,PO303,PO171 ? fredo181 Modular V10 (6.8l) 3 09-15-2009 11:08 AM
New member needing LOTS OF HELP tmartinford New Member Introductions 1 04-02-2007 02:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
