08 f250 5.4- PO420 and 430, rich startup
Not sure where to start with this. This is a beat up farm truck so I dont want to throw a lot of money at it- as in I want to avoid the dealership.
On a cold start, it smokes a good bit- I can tell it is super rich. Otherwise it seems to run pretty good. It feels a little underpowered, but the only comparison I have is a 2010 F150. I assume the 5.4 should be a pig in an f250. The exhaust note is pretty loud for a stock truck, so I assume the cat substrate is broken up. I am not worried about that as much as the rich startup. I am worried I may have a leaky injector. The truck has 139k miles, but had a new engine installed at the dealership at ~70k. There is also a code for PCM failure, Po606 I think. I will have to check that one when I get home. |
Try this---from the comfort of your inside seat: ActronŽ :)
Originally Posted by JWA
(Post 14105953)
